Old 04-11-2011, 05:29 PM   #1 (permalink)
Nivedita
Posts: n/a
Smile Need Help in software
Hi,
I'm working on a project for M.Tech . My project is about writing test scenarios/cases from UML diagram. Does anybody knows about any existing tool for this purpose?? Please reply..
Old 04-11-2011, 07:57 PM   #2 (permalink)
I'm a Wannabe Hacker
Prime_Coder's Avatar
Default Re: Need Help in software
I had used EDraw Max for this purpose on my friends laptop.
Don't know whether this is right for you, but you can check out other options through this link.
List of Unified Modeling Language tools
Prime_Coder is offline   Reply With Quote
Old 05-11-2011, 10:00 AM   #3 (permalink)
Fullbring
Zangetsu's Avatar
@Nivedita: there are many..the one have used in college is Eclipse & Rational Rose.
Old 05-11-2011, 11:39 AM   #4 (permalink)
Resistance is Futile.
coolpcguy's Avatar
Dia is pretty sweet.
Dia draws your structured diagrams: Free Windows, Mac OS X and Linux version of the popular open source program
Also, there's the heavyweight Visio - which will infuriate at times with it's idiotic behavior but is pretty powerful.
Super User ♦ Moderator | chip/tech2 forum Mod | About me
Gadgets: HP Envy 14 | Google Cr-48 | D-Link DGL 4500 | Denon AH-C360 | Fiio E5 | Galaxy SII GT-I9100 | Dell U2312HM
coolpcguy is offline   Reply With Quote
Old 07-11-2011, 11:47 PM   #5 (permalink)
Nivedita
Posts: n/a
Unhappy Re: Need Help in software
Thanks for your reply.. But I'm not looking for a tool to draw UML diagram. I want to know about a software which could write test cases directly if UML diagram is given to it. If you know about it, then please advice...
Old 08-11-2011, 08:17 PM   #6 (permalink)
BMG ftw!!
d6bmg's Avatar
Try Concept Draw suite.
d6bmg is offline   Reply With Quote
