29-10-2011, 02:57 PM
Drive lock
Hi, I want my D: drive to be accessible to me only which holds many personal files. Anybody from other accounts should not be able to access those files. Windows 7 pre-installed Bitlocker doesnot work fine. Can someone help me ?
The first step to getting the things you want out of life is this: Decide what you want.
29-10-2011, 04:31 PM
Re: Drive lock
right click the drive click properties u can modify the required settings from the security tab
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
29-10-2011, 06:18 PM
Computer Addict
Re: Drive lock
There are many free folder lock tools available, try one.
30-10-2011, 12:16 AM
Re: Drive lock
can you name some good. I have some but they are with issues.
30-10-2011, 12:30 AM
Stuck in Time...
Re: Drive lock
Best option would be to truly hide your complete partition or drive(s) as you call it, using utilities provided by software such as "Tune Up Utilities".
You can get a free and legal license for TuneUp Utilities 2010, from this promotion offer.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
30-10-2011, 10:53 AM
Re: Drive lock
Okay, thank you
30-10-2011, 01:52 PM
Re: Drive lock
@ OP please search before making new thread, I had just answered this Few days back. xp and win 7 has same process.. You don't need any 3rd party software for this. It can be easily done without any softwares.. so here is it.
login with Administer account
Your Disk/partition should be NTFS
You administer account should have passwords
That other users should not have administer privileges, their account should be standard.
Now Right click on Drives which You like restrict access from another users
click on Properties and go to Security Tab..
click on Edit. then select user from list .If user not in list then click on add. type user name in box and then on right, click on check names. then click OK
after selecting that user, below u will see list with check boxes. so just deny every thing.
Work done.. click ok and Exit the Dialog box.
| Athlon II X4 635 @ 2.9Ghz | | Gigabyte GA-MA785GMT-US2H | | Kingston 2x2 Gb 1333Mhz DDR3 | | WDC 500Gb Green | | Palit GTS 250 512mb | | Tagan 500W | | Samsung B2030 | | Lg DVD Writer |
30-10-2011, 09:05 PM
Re: Drive lock
Yes I have done these things before, but the problem is that few years ago, while using XP, my OS got corrupted. Then after reinstalling XP, I was not able to access my E: drive. Then I have to recover the data in E: drive using a linux live cd and then format the drive. Thats why I am not going for this method.
31-10-2011, 05:05 AM
Fast 'N' Furious
Re: Drive lock
I would suggest using T r u e C r y p t
Free open-source disk encryption software for Windows 7/Vista/XP, Mac OS X, and Linux
Features :
Creates a virtual encrypted disk within a file and mounts it as a real disk.
Encrypts an entire partition or storage device such as USB flash drive or hard drive.
Encrypts a partition or drive where Windows is installed (pre-boot authentication).
Encryption is automatic, real-time (on-the-fly) and transparent.
Parallelization and pipelining allow data to be read and written as fast as if the drive was not encrypted.
Encryption can be hardware-accelerated on modern processors.
Provides plausible deniability, in case an adversary forces you to reveal the password:
Hidden volume (steganography) and hidden operating system.
get it from here : TrueCrypt - Free Open-Source On-The-Fly Disk Encryption Software for Windows 7/Vista/XP, Mac OS X and Linux
31-10-2011, 07:31 PM
Re: Drive lock
@Topgear... Thank you
01-11-2011, 03:31 AM
Fast 'N' Furious
Re: Drive lock
^^ you are welcome
TrueCrypt is the best free open source app out there for these kind of needs - I first came to know about this on 2006 and still I'm using it - TrueCrypt even has some very good BenchMark Features which I use - Overall this is a great piece of app and no freeware or shareware so far can't compete with this IMO - a big thanks goes to it's developers
