Old 26-10-2011, 08:07 PM   #1 (permalink)
curioustechy's Avatar
Unhappy <<please help>>
My system was working all right till i installed a win8 theme... now my windows explorer has stopped functioning. when i open a windows explorer, [say 'My Computer'], a window comes with the title bar(sans any title) and address bar(sans any address) only and the mouse pointer blinks as if in busy mode and nothing else appears... i tried to change my windows theme... alas! i couldn't access since that too has to manifest in a windows explorer.. i tried system restore but in vain... what else can be done to restore my system...plz help
curioustechy is offline   Reply With Quote
Old 26-10-2011, 08:41 PM   #2 (permalink)
Default Re: <<please help>>
Please avoid thread titles like <<<please help>>>>
They do no good. and dont attract much help. Read the Forum Rules
Check your taskmanager for processes consuming too much procesing power. Post a screenshot if possible,
also it seems you are virus infected. do a scan using a online AV - HouseCall - Free Online Virus Scan - Trend Micro USA
Old 26-10-2011, 09:12 PM   #3 (permalink)
JojoTheDragon's Avatar
Lol, you used a theme pack and most probably it ruined some system files.
One of these might solve the problem:
1)Do a system restore
2)Install the theme again and uninstall it
3)Format windows (if nothing else works).
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline   Reply With Quote
Old 26-10-2011, 09:58 PM   #4 (permalink)
clmlbx's Avatar
Post a screen shot of your task manager..or give log of "hijack this"
You might also try booting to safe mode and then uninstall that theme. If this does not work
Try Repairing the Windows thru windows Cd/DVD (Which OS are you using)
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is offline   Reply With Quote
Old 27-10-2011, 12:15 AM   #5 (permalink)
Mozilla Rep
sygeek's Avatar
Try installing any other 3rd party theme.
sygeek is online now   Reply With Quote
Old 27-10-2011, 08:27 AM   #6 (permalink)
sorry sir, u r right.. in future i'll take care... i was in hurry n worry
i did a system restore and it didnt work..also i deleted the theme from windows/resources/themes (i accessed the location through task manager - new task)
formating windows is the end of the story..i would like to know something better
Old 27-10-2011, 08:29 AM   #7 (permalink)
Did you try the AntiVirus scan as suggested? Also post a pic of the processes Tab of taskmanager
Old 27-10-2011, 08:37 AM   #8 (permalink)
I'm using microsoft security essentials and am uptodate
my taskmanager screenshots are attached
Old 27-10-2011, 08:39 AM   #9 (permalink)
i didnt get 'hijack this'
i did try safe mode uninstallation
im not having win disc (im using win7 ultimate 32bit)
Old 27-10-2011, 08:47 AM   #10 (permalink)
Looks like Speedup My PC software is bloating your CPU usage. Try disabling/uninstalling that. I am sure it will help
Even my PC was slow when I was using it. Tune up Utilities is LOT better
also close powersuite.exe
Old 27-10-2011, 09:20 AM   #11 (permalink)
Mozilla Rep
sygeek's Avatar
Try this:
sfc /scannow
It may ask for your windows installation cd. The process will also take some time, so be patient.
This should probably fix your problem.
Just a few questions now. Did you try patching windows files before installing this theme? If so, which software did you use?
ugh, and please, fix your startup configuration.
Old 27-10-2011, 01:49 PM   #12 (permalink)
Originally Posted by sygeek View Post
Try this:
i did that... it did find some issues but told that it cant fix those issues... didnt ask for any windows disk.... by the way..i did patch three files using unversal theme patcher... i patched uxtheme.dll, themeui.dll & themeservice.dll... later on i replaced Shell32.dll, ExplorerFrame.dll
and OobeFldr.dll with that given with the mac-os leopord theme.... i tried to do that for explorer.exe also but it failed... the mac theme workded almost fine.... then after some time i installed a win 8 theme... i just copied the given files to windows\resources\theme... thats all... everything gone
Old 27-10-2011, 02:02 PM   #13 (permalink)
Mozilla Rep
sygeek's Avatar
This is the problem, those files are not compatible with your system. Tell me your operating system, and the architecture it is using.
I'll compile the original files into a zip so you can replace with the corrupted ones.
Old 28-10-2011, 06:43 AM   #14 (permalink)
Computer Addict
meetdilip's Avatar
Insert the Windows CD / DVD into drive and use sfc/scannow command. It will fix the damaged system files. Or use any 3 rd party tool which allow system restore.
meetdilip is offline   Reply With Quote
Old 28-10-2011, 11:03 AM   #15 (permalink)
clmlbx's Avatar
He is using Windows 7 ultimate 32 bit . I don't have 32 bit Os so can't help.. Also OP let us know if you have installed SP or not.
Old 28-10-2011, 11:36 AM   #16 (permalink)
Mozilla Rep
sygeek's Avatar
@OP: Download this and extract into "C:\Windows\System32". You may need full UAC permissions for this. After replacing, do a system restart.
Report back with the results.
Old 28-10-2011, 01:12 PM   #17 (permalink)
i'm using win 7 ultimate 32 bit .plz do
yes SP.1
i'm not able to uninstall these sfwrs...i disabled it through task mgr..it didnt help
Old 28-10-2011, 01:21 PM   #18 (permalink)
Mozilla Rep
sygeek's Avatar
yes SP.1
you missed my post
Old 28-10-2011, 07:22 PM   #19 (permalink)
i replaced the files with those u provided... but in vain... no change... what else can i do
the antivirus u suggested could not be tried...i downloaded it and started installation, but it didnt finish even after 5 hrs... so i stopped that... i didnt get ur second question as i've already posted the screenshots of the processes in task mgr..
Old 28-10-2011, 07:41 PM   #20 (permalink)
Mozilla Rep
sygeek's Avatar
i replaced the files with those u provided... but in vain... no change... what else can i do..
reinstall the os.
Old 28-10-2011, 09:06 PM   #21 (permalink)
OP: Mind giving us the theme name and link .
TDF @ Steam
Old 29-10-2011, 01:03 PM   #22 (permalink)
Your Ad here
nisargshah95's Avatar
Lightbulb Re: <<please help>>
Provide with as many details as you can so we can approach you with better solution...
“The Web is like a dominatrix. Everywhere I turn, I see little buttons ordering me to Submit.”
ASUS P5KPL AM/PS | P4 @ 3.07GHz | Ubuntu 11.04 / Win Server 2k8 / XP SP3 | 1GB DDR2 | Samsung HD080HJ 80GB
nisargshah95 is offline   Reply With Quote
Old 29-10-2011, 09:21 PM   #23 (permalink)
i did sfc/ scannow.. it showed that there are some errors that can't be fixed... i'm not able to attach the log file in which the information is saved, as this forum has limitations in uploading particular files and above particular sizes..
its windows 8 theme... sorry i'm not remembering the link....
what else information can i provide ?
Is my antivirus trustworthy (microsoft security essentials)?
Old 29-10-2011, 09:27 PM   #24 (permalink)
clmlbx's Avatar
Antivirus is trustworthy but now apparently you have to re-install os
