Old 30-09-2011, 11:16 PM   #1 (permalink)
mortal kombat
quan chi's Avatar
Default Windows 7 connection problem.
Guys i have a dual boot xp and windows 7. windows 7 is acting strangely since yesterday.After few hrs the net connection disconnects itself automatically after few hrs.Even it says there is no lan connection when there is.After restart it again works fine.
In xp however i havent faced this problem yet..
now what may be the problem.
quan chi is online now   Reply With Quote
Old 01-10-2011, 12:33 AM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Windows 7 connection problem.
Install the Win7 ethernet drivers again.
asingh is offline   Reply With Quote
Old 01-10-2011, 01:16 AM   #3 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Maybe Windows is switching off the network card to save power ? You didnt tell if its wifi connection you are using or a wired one ... Anyway whichever it is try this :
Start > Run > Devmgmt.msc
Expand the Network Adapters section and select your network adapter by double clicking on it .. Click on Power Management and untick "Allow the computer to turn off this device to save power" ..
Also check your power profile : Start > Run > Powercfg.cpl ..
Click on "Change plan settings" for your active power plan ..
Click on "Change Advanced Power settings" in the preceding dialog box ..
Check your network adapters settings in the list ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline   Reply With Quote
Old 01-10-2011, 07:08 AM   #4 (permalink)
if your Lan connection remains idle for a long time the Internet automatically gets disconnected. And probably Windows switches off your Ethernet to save power.
Old 01-10-2011, 05:25 PM   #5 (permalink)
Can you run "netsh int tcp show global" and post back the o/p?
Its either getting idle as suggested above or there is a drop in packets....
rawgeek is offline   Reply With Quote
