Old 26-09-2011, 01:32 PM   #1 (permalink)
Racing 24X7
NitrousNavneet's Avatar
Default problem with CHKDSK
When I starts my PC the CHKDSK always checks My drive G.
It contains only MY photos and camera videos of 14.4gb
And Photoshop 7 installed of 113gb.
"Those Who Are Afraid OF Falling Will Never BE Able To Fly"
>>Intel dual core 2.20 GHz
>>Asus P5GC-MX/1333
>>2Gb Ram
>>500Gb Seagate
>>Asus Eah4350 Silent Graphics Card
>>Windows 7 ultimate X64
Please
Help
NitrousNavneet is offline   Reply With Quote
Old 26-09-2011, 02:25 PM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: problem with CHKDSK
so you want to get rid of chkdsk scanning!..?
just run scandisk (right click on that drive and properties) by enabling thorough check and automatic fix .
better try to take a backup of that drive before running chkdsk
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
Old 26-09-2011, 03:40 PM   #3 (permalink)
mithun_mrg's Avatar
@op please backup ur data asap
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 26-09-2011, 03:49 PM   #4 (permalink)
Fullbring
Zangetsu's Avatar
@NitrousNavneet: right click the G: drive & select Tools Tab & uncheck the checkbox in
Error-Checking group.
Old 27-09-2011, 05:23 AM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
open a command prompt window and type this :
chkntfs G /x
hit enter and reboot your pc - the issue should be solved
ToPsPeEeD = FaSt BuT StEaDy
topgear is online now   Reply With Quote
Old 06-10-2011, 03:09 PM   #6 (permalink)
Racing 24X7
What is use of THIS SCANNING
>>Asus P5GC-MX/1333
>>2Gb Ram
>>500Gb Seagate
Please
Help
Old 07-10-2011, 02:50 AM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ BTW, the proper command format for you should be :
chkntfs /x g:
to know more about this take a look at here
CHKNTFS.EXE: What You Can Use It For
Old 07-10-2011, 12:24 PM   #8 (permalink)
Racing 24X7
Thanks to all I am recovered from this prob.
But my Next Prob. is
Where is Side BOX ??????
I am feeling odd without it.
>>Asus P5GC-MX/1333
>>2Gb Ram
>>500Gb Seagate
Please
Help
Old 07-10-2011, 09:02 PM   #9 (permalink)
khmadhu's Avatar
my computer properties->advanced->performance->visual effects
in that make sure this option is checked. "use common tasks in folders". if not, enable it.
