Old 24-09-2011, 01:03 PM   #1 (permalink)
pratik385's Avatar
Default s/w to convert low reso to high reso wallpapers !
Guys is there any s/w which can convert low reso wallpaper to high reso wallpaper ? My dell xps has 1080p reso and many wallpaper which are not of 1920X1080 reso not look good.
Dell XPS 15 || LG Optimus One || Sony PS2 || Apple iNano 4gb || Sennheiser CX180
"Sometime we lose sometime we win, next year we try again"
pratik385 is offline   Reply With Quote
Old 24-09-2011, 01:32 PM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: s/w to convert low reso to high reso wallpapers !
I don't think there will be any...coz increasing the resolution of images will require up-scaling(like zooming)....so pixels will be clearly visible...& if the original resolution if very low then up-scaling @1080p will make the image like mosaic...
Old 24-09-2011, 02:13 PM   #3 (permalink)
pratik385's Avatar
damn, zangetsu i cant find great wallpapers of 1920X1080
what about this?
Old 24-09-2011, 02:17 PM   #4 (permalink)
Living to Play
gameranand's Avatar
You can't increase the resolution without loosing the quality.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 24-09-2011, 02:33 PM   #5 (permalink)
pratik385's Avatar
any site then which has great wallpapers !
Old 24-09-2011, 03:07 PM   #6 (permalink)
Fullbring
Zangetsu's Avatar
there are many...
try HDwallpapers.com
or just type "wallpapers 1080p"... u will get a whooping list in google
Old 24-09-2011, 03:45 PM   #7 (permalink)
if you have a sample of the pic you want in Full HD resolution, use tineye to search for same pic. there maybe some higher resolution pic avl for the same.
Old 24-09-2011, 04:02 PM   #8 (permalink)
Fullbring
Zangetsu's Avatar
& Google image search will also do the job
Old 24-09-2011, 05:34 PM   #9 (permalink)
JojoTheDragon's Avatar
As said by others earlier, resizing/up scaling images kill the quality.
And for hd wallpapers check out : www.wallbase.net Its the best out there IMO.
EDIT:
@OP: That liquid resize does seem to work with minimum quality loss. You can try it out, its really easy. I used it's GIMP plug-in but the results were not that satisfactory.
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline   Reply With Quote
Old 27-09-2011, 04:07 PM   #10 (permalink)
Technoholik !!
Tech&ME's Avatar
You can resize the wallpapers to HD resolution with great quality.
There is software for that:
Photo Zoom 4
I have used it on my Macintosh, and is a great software. ( I got a free promo offer )
[Desktop]
[Laptop]
Tech&ME is offline   Reply With Quote
