Old 16-09-2011, 08:00 PM   #1 (permalink)
hansraj's Avatar
Default Two querries- Disabling storage devices & monitoring user logon/logoff timings
Hello friends,
I am trying to find a method where in I can use only specific pendrive/storage devices on my office pcs. While doing so, the account has to be an administrator account as well because those specific pendrive/storage devices have to be formatted routinely. As a limited or standard user people wont be able to do that. Second issue is; I want to keep a log of the timings at which the users log on and log off.
Any help shall be greatly appreciated. Looking forward!!
OS: Win7 and XP both
I did some programming in C# using MS visual studio 08. So suggestions regarding codes is fine too.
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline   Reply With Quote
Old 17-09-2011, 09:21 AM   #2 (permalink)
BIOS Terminator
nims11's Avatar
Default Re: Two querries- Disabling storage devices & monitoring user logon/logoff timings
first query :
you can use desktop central to manage USB devices
Remote Windows Desktop Management and Desktop Administration Software - ManageEngine Desktop Central
second query :
create batch files logon.bat and logoff.bat
logon.bat :
echo Logon : %USERNAME% at %DATE% %TIME% >> C:\x.log
logoff.bat :
echo Logoff : %USERNAME% at %DATE% %TIME% >> C:\x.log
goto Run->gpedit.msc->User Configuration->Windows Settings->Scripts
and add the scripts.
nims11 is online now   Reply With Quote
Old 18-09-2011, 01:24 PM   #3 (permalink)
hansraj's Avatar
Originally Posted by nims11 View Post
first query :
second query :
logon.bat :
logoff.bat :
Thanks a ton... this part is done and achieved.
I downloaded it but I am unable to complete the disabling of selective USB storage devices in that. If you are using it, can you share how to do that.
Old 18-09-2011, 02:58 PM   #4 (permalink)
BIOS Terminator
nims11's Avatar
nah, i have never used it. google results show few good ones none of which i am satisfied with. see for yourself : allow specific usb devices - Google Search
Old 18-09-2011, 07:58 PM   #5 (permalink)
hansraj's Avatar
Thanks Nims. Found a software by following the method as suggested by you. USB Block. Some times googling with exactly key words is so important that you just cant succeed otherwise. I tried earlier but with other key words
Anyways ... thank you once again.
- by Niilesh
- by chris
- by gforz
- by Anorion
- by tkin
