Old 13-09-2011, 03:59 PM   #1 (permalink)
sujeet2555's Avatar
Default 16 bit MS-DOS Subsystem error
hi
i have window7,32 bit.recently ,i was having error of fatal error c000021a after pc turned off directly.using boot disk i restored the corrupt "software" file in system32/config folder with a backup.after that pc started fine but i am getting this error "16 bit MS-DOS Subsystem The NTVDM CPU has encountered an illegal instruction." right after logon..i think there are some other corrupt file also.
i have ran chkdsk /r .using google i found out that it is related to Autoexec.nt and Config.nt but i havened dealt with them before. can you guide me to the right direction?
s.k.
sujeet2555 is offline   Reply With Quote
Old 15-09-2011, 08:43 AM   #2 (permalink)
mithun_mrg's Avatar
Default Re: 16 bit MS-DOS Subsystem error
Follow the instructions here
Troubleshooting NTVDM and WOW Startup Errors
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 15-09-2011, 02:30 PM   #3 (permalink)
sujeet2555's Avatar
Originally Posted by mithun_mrg View Post
I have been there but is it safe to carry out the said method.i mean if i do something wrong,will it hampers my system?
here is my autoexec.nt autoexec - Pastebin.com
Config.nt REM Windows MS-DOS Startup File REM REM CONFIG.SYS vs CONFIG.NT REM CONFIG.SY - Pastebin.com
also i recently recovered from fatal error c000021a.
s.k.
Old 15-09-2011, 03:54 PM   #4 (permalink)
mithun_mrg's Avatar
increase the files count to 250 in ur config.nt & see
also add this line without quotes
"shell=%SystemRoot%\System32\Command.com /e:4096"
& to add always take a backup of ur sensitive data before doing anything because modifying registry or system files carry certain risks & don't blame me on any member if something going wrong
Old 16-09-2011, 02:40 PM   #5 (permalink)
sujeet2555's Avatar
tried , but still getting errors.how to i extract a specific file from window7 disc and replace the file on my system if corrupted.
s.k.
Old 16-09-2011, 03:42 PM   #6 (permalink)
mithun_mrg's Avatar
then first try sfc/scanow at command prompt if that fails to resolve ur problem then use this guide to extract & replace the corrupted file
Extract Files from Windows 7 Installation DVD - Windows 7 Forums
Old 19-09-2011, 07:10 PM   #7 (permalink)
sujeet2555's Avatar
can anybody tell me what are the specific files that are related to this errors?
i tried changing himem.sys but still error occurs.
s.k.
Old 20-09-2011, 06:59 AM   #8 (permalink)
mithun_mrg's Avatar
^^have u changed it from "sysedit"
Old 20-09-2011, 04:57 PM   #9 (permalink)
sujeet2555's Avatar
sorry for using wrong word ,i don't changed but replaced it with a backup file from winsxs folder.
also using sysedit give error "
System Error
The Win16 Subsystem was unable to enter Protected Mode, DOSX.EXE must be in your AUTOEXEC.NT and present in your PATH.
s.k.
Old 20-09-2011, 05:08 PM   #10 (permalink)
mithun_mrg's Avatar
please elaborate how did u open sysedit
Old 20-09-2011, 06:35 PM   #11 (permalink)
sujeet2555's Avatar
i tried to run sysedit by using "run" and giving sysedit command in elevated command prompt .both return the previous error.
s.k.
Old 21-09-2011, 07:29 AM   #12 (permalink)
mithun_mrg's Avatar
go to folder options select show hidden files & uncheck the option hide protected os files
go to c: open the file config in notepad add these lines & reboot
dos=high, umb
device=%SystemRoot%\system32\himem.sys
files=20
if these fails try running this command from run
cmd /c copy /y %windir%\repair\autoexec.nt %windir%\system32
try these & get back
Old 21-09-2011, 03:20 PM   #13 (permalink)
Electronic.
Neuron's Avatar
What i think is that some startup program has gone corrupted.Use Ccleaner and try disabling unwanted startup entries.
I don't always make sense,but when I do,I don't.
Neuron is offline   Reply With Quote
Old 21-09-2011, 07:14 PM   #14 (permalink)
sujeet2555's Avatar
dos=high, umb
files=20
tried both of them but still getting errors but i have found that at login when i get this error ,ntvdm.exe running .
using process explorer(sysinternals) i got this
image file- ntvdm.exe version-6.1.7600.16385
path-c:\windows\system32\ntvdm.exe
command line-c:\windows\system32\ntvdm.exe -i 1
current directory-f:\program files\startdock\object desktop\deskscapes\
parent - <non-existent process>(2644)
i am using stardock fences on my desktop but i am not using deskscapes right now.
s.k.
Old 22-09-2011, 07:09 AM   #15 (permalink)
mithun_mrg's Avatar
disable all start up items from msconfig & see the same error pops or not
Old 22-09-2011, 05:56 PM   #16 (permalink)
sujeet2555's Avatar
i have only comodo internet security as startup and disbling it does not affect the error.
s.k.
Old 22-09-2011, 06:02 PM   #17 (permalink)
mithun_mrg's Avatar
then the last option for u is system restore
Old 22-10-2011, 11:58 PM   #18 (permalink)
sujeet2555's Avatar
sorry for late reply as i was oflline.BTW here is a screenshot of the error
http://i54.tinypic.com/24w5x02.png
i used the sfc command but still the error as usual.and now after doing sfc my system just freeze up while doing anything .its not specific to any program or time.even task manager don't come up by ctrl+alt+del.
pc don't don't respond to any keypressses.usually num lock indicator was the indicator of pc hanging for me but it is normal.
s.k.
- by Niilesh
- by chris
- by gforz
- by Anorion
- by tkin
