10-09-2011, 09:29 AM
When dvd inserted into the dvd drive,the dvd drive doesnot respond
Hi,
Whenver i insert the whatever type of dvd/cd in to the dvd rom driver,the ;laptop doesnot read the dvd by the dvd rom and it does unresponsive for the long time and i have to shut down by pressing the power off button,what is the problem,
my config; laptop with window 7 intel dual core2duo cpu with 500 gn hdd and 2 gn of ram.
Thanks
10-09-2011, 09:04 PM
Stuck in Time...
Re: When dvd inserted into the dvd drive,the dvd drive doesnot respond
Only two things can be the problem in this case.
1. The disks, which are somehow unreadable on your laptop's DVD drive.
2. The drive, which can't read ANY disks.
This unresponsive behavior happens with me, with a few disks, but I don't have to shutdown the PC to get out of the problem. Usually, the unresponsive state disappears after I take the disk out of the drive, by pressing the Eject button.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
12-09-2011, 09:37 AM
@thetechfreak: No such virus as the pc is protected by Quick heal 2011.I am using Ccleaner since loong.
When dvd inserted,the pc goes unresponsive and takes long time to read the contents and the majority pc hangs and I have to restart the pc.
@vineet369:it is not so that dvd drive doesnto read the contents,it reads but when the dvd inserted the pc goes hangs and unresponsive for the long time.
cheers
12-09-2011, 09:58 AM
Well I think the drive might be damaged. Try doing a system restore to a date before this started happening. Any hardware or major software change you made recently?
12-09-2011, 10:02 AM
Nope, the drive works but works lately which makes the pc hangs and i have to restart
12-09-2011, 10:08 AM
BIOS Terminator
happens with me with few disks, i just kill explorer.exe and everything becomes okay. if you have a Linux Live CD, boot from it and see if your drive is reading dvds properly or not. if it reads properly, then your Windows is having some problems/viruses or otherwise your drive/dvd is faulty.
12-09-2011, 10:31 AM
it reads but the pc hangs for the long time
12-09-2011, 10:35 AM
Could you post a screen shot of the task manager where the processes are listed. I have suspicions of some process consuming 100% processor usage.
So please post a photo at the earliest
12-09-2011, 10:47 AM
it is max 70%
12-09-2011, 11:09 AM
Uhu, Not Gonna Happen!
Used to happen with me when I pop in scratched CD/DVDs or unreadable disks in other words. Could be the same problem as vineet said above.
My personal blog - http://gagan.scholarguru.com
