Old 09-09-2011, 07:48 PM   #1 (permalink)
mortal kombat
quan chi's Avatar
Default Strange opera slowdown problem.
I was browsing for sometime then suddenly the net went off.Then when again it came back and i tried to open a site using opera google search engine.(pls refer the image)Generally i use that only for searching.
1.It said the browser is no longer supported and gave an option to update.
2.I did and saved the downloaded file on the desktop.
3.When i double clicked that file after few secs it just vanished.But still opera gave same message.
4.I repeated the steps again but in vain.
5.Then i restarted the system.Now if i dont connect to the internet the system works fine but if i connect after few secs it slows down too much.Task manager shows 100% cpu usage.Even it takes ages to refresh.
I am on windows 7 ultimate (dual boot) sp1.
quan chi is offline   Reply With Quote
Old 10-09-2011, 12:12 AM   #2 (permalink)
Crowman
Krow's Avatar
Default Re: Strange opera slowdown problem.
Which file has most CPU usage?
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is online now   Reply With Quote
Old 10-09-2011, 02:55 AM   #3 (permalink)
mortal kombat
quan chi's Avatar
There is a certain program called svhost.exe showing usage of 98% of cpu.When i delete that it works fine.
But now i even cant get a connection to the net it is not allowing.
kaspersky couldnt find any virus too.
Old 10-09-2011, 07:26 AM   #4 (permalink)
mithun_mrg's Avatar
@op try using system restore
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 10-09-2011, 10:52 AM   #5 (permalink)
mortal kombat
quan chi's Avatar
^^unfortunately that is turned off.Any more ideas infact task manager shows there are many svhost programs running.But deleting that particular one solves the problem but then it prevents the net access.
Old 10-09-2011, 11:43 AM   #6 (permalink)
mithun_mrg's Avatar
remove & reinstall opera
Old 10-09-2011, 12:01 PM   #7 (permalink)
@quan chi, download & scan using emsisoft antimalware. if you can't (size is 110Mb + updates), download McAfee AVERT Stinger & give a quick scan (6Mb only).
Sam is offline   Reply With Quote
Old 10-09-2011, 02:53 PM   #8 (permalink)
mortal kombat
quan chi's Avatar
^^i used MalwareBytes it worked.But it seems it is unable to delete that file because i am getting this message randomly
(The port keeps on changing)
even after doing full system scan and removing the ,malicious items.Can anybody please help in deleting that file completely.
Old 10-09-2011, 03:43 PM   #9 (permalink)
mithun_mrg's Avatar
try runnning the mrt tool in safe mode and do a complete system scan go to start run >"mrt>ok
alternatively u can download the tool from here
The Microsoft Windows Malicious Software Removal Tool helps remove specific, prevalent malicious software from computers that are running Windows 7, Windows Vista, Windows Server 2003, Windows Server 2008, or Windows XP
Old 12-09-2011, 04:47 PM   #10 (permalink)
Crowman
Krow's Avatar
Avast! anti virus has a boot time scan feature. You could run that. It scans the PC before the PC boots.
- by Niilesh
- by chris
- by gforz
- by Anorion
- by tkin
