Old 06-09-2011, 11:56 PM   #1 (permalink)
Freelance web designer
gdebojyoti's Avatar
Question Ubuntu installation problems
My laptop runs on a 64 bit edition of Windows 7 Ultimate.
Every time I try to install Ubuntu in my laptop (via the Wubi installer), the following error is displayed in the middle of the installation (please see attached image "ubuntu-error.jpg").
Needless to say that the installation fails and Ubuntu does not get installed.
I have tried installing Ubuntu 11.04 (32 & 64 bit), Digit customised Ubuntu 11.04 and Ubuntu 10.04 (32 bit). But all my attempts were in vain.
Please tell me how I will be able to run Ubuntu on my computer. Is the problem arising from the 64 bit edition of Windows?
gdebojyoti is offline   Reply With Quote
Old 07-09-2011, 12:14 AM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: Ubuntu installation problems
Why don't you try burning a Live CD and installing it. Wubi is not recommended at all.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline   Reply With Quote
Old 07-09-2011, 12:21 PM   #3 (permalink)
Rising Sun!
buddyram's Avatar
Yeah! try the digit's customized OS. Its a good one
“An expert is a man who tells you a simple thing in a confused way in such a fashion as to make you think the confusion is your own fault.” – William Castle
buddyram is offline   Reply With Quote
Old 07-09-2011, 02:30 PM   #4 (permalink)
BIOS Terminator
nims11's Avatar
don't install through Wubi. It has its own share of problems.
burn a LiveCD as suggested by krishnandu
or
if you have a pen drive, use YUMI or unetbootin
nims11 is online now   Reply With Quote
Old 16-09-2011, 09:16 PM   #5 (permalink)
gdebojyoti's Avatar
Sorry for my very late response.
Yes, I am aware of the fact that Wubi has its own share of problems. But I want to know why it's not working for my 64bit Windows 7 Ultimate. Previously, it used to work on my desktop computer ( XP Professional 32 bit - SP 2 & 3 ).
Will someone please tell me the reason (and the way to rectify it)?
Old 17-09-2011, 08:52 AM   #6 (permalink)
BIOS Terminator
nims11's Avatar
does it work if you install it in some other partitions?
also, post the log file generated according to the error message.
Old 17-09-2011, 10:43 AM   #7 (permalink)
gdebojyoti's Avatar
Okay. I don't know whether this is success or failure. You decide for yourself.
I burnt 2 disks with 32 and 64 bit images of Ubuntu 11.04. But I did not even get the options menu ( Try Live CD, Install to disk, etc ) when I booted using them. All I got were black screens. ( I tried multiple times ).
Then I opened up Windows and discovered that I could install the 'Ubuntu installer' if I installed Wubi in C: drive. ( I don't remember whether I had tried installing Wubi in C: ). So my 2 CDs were wasted.
Anyway, I restarted my laptop and selected Ubuntu from the boot menu. And then.... again... A big black screen!
I tried using the Wubi installers of Ubuntu 11.04 32 & 64 bit versions. I also tried with the ISO file of the Digit customised Ubuntu 11.04. The results were same - static black screens!!
Now I am going to recheck if the Wubi installers are working on my other drives ( other than drive C: ).
Summary: I managed to install Wubi, but failed to boot using Ubuntu!
Old 17-09-2011, 11:53 AM   #8 (permalink)
gdebojyoti's Avatar
Nope, it's not working in other partitions.
The links to logfiles are:
http://sociallizze.in/logfiles/wubi-10.10-rev197.log
http://sociallizze.in/logfiles/wubi-11.04-rev211.log
- by Niilesh
- by chris
- by gforz
- by Anorion
- by tkin
