Old 13-08-2011, 08:11 PM   #1 (permalink)
Default HP DV6-6121TX graphics switching issue
Hi,
I recently bought a HP Pavillion DV6-6121TX laptop and i am facing a problem switching from the Intel Graphics to ATI Radeon 6700 2 GB graphics card. How do i do that?
When I use the Catalyst Control Center to assign power saving or performance mode to different applications, it doesnt work. I assigned Performance mode to windows media player classic, but when i play any video, it doesn't play it remains stopped.
Is there any solution for this?
tamalsen is offline   Reply With Quote
Old 13-08-2011, 08:43 PM   #2 (permalink)
Manchester United <3
Ishu Gupta's Avatar
Default Re: HP DV6-6121TX graphics switching issue
THAT is the correct way to switch graphics.
You don't need the 6770M to play movies. HD3000 is more than enough.
Probably a problem with your file.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 13-08-2011, 09:26 PM   #3 (permalink)
I have played more than dozen different files, divx, avi, xvid, mkv, NONE of them play when i assign it under the high performance mode.
Old 13-08-2011, 09:30 PM   #4 (permalink)
Ishu Gupta's Avatar
Do they work on power saving mode?
Old 14-08-2011, 12:59 AM   #5 (permalink)
Yeah, all of those files work fine in the power saving mode. Moreover, the playback is kind of blocky. Its not as great as it is on my 2 year old desktop.But the bottomline is that in high performance mode doesnt allow for playback of the videos.
- by Niilesh
- by chris
- by gforz
- by Anorion
- by tkin
