Old 12-08-2011, 02:53 PM   #1 (permalink)
Default Need help, making chart bar
I have to make a chart (bar chart) for 30 people of 10-12 months.
After entering all the datas and when i converted them to bar chart in the excel sheet function, i am getting very small images which is very difficult to see. This is mainly due to the large number of people, i guess.
Can someone please help on how to make this viewable easily. Any software or any alternate suggestion?
The chart should be easily viewable on computer screen, without scrolling down much or enlarging the image.
dinga03 is offline   Reply With Quote
Old 12-08-2011, 03:39 PM   #2 (permalink)
Default Re: Need help, making chart bar
This video should have what you want -
thetechfreak is online now   Reply With Quote
Old 12-08-2011, 04:22 PM   #3 (permalink)
Super Moderator
asingh's Avatar
Let me know, if you are still stuck.
asingh is offline   Reply With Quote
Old 14-08-2011, 11:27 AM   #4 (permalink)
@thefreak.. thanks for the video and sorry i am a bit late in replying.
Frankly, this is not my solution. I know how to create the chart..but my problem is when i am using/creating the data or more than 30 people for 10-12 months, the chart gets really really small and it is very hard to look at it.
My question is, is there anyway of creating another chart which can be seen and observe easily.
- by Niilesh
- by chris
- by gforz
- by Anorion
- by tkin
