Results 1 to 13 of 13
Thread: Help to install xp
11-08-2011, 04:02 PM #1Right Off the Assembly Line
- Join Date
- Mar 2011
- Posts
- 12
Help to install xp
I need help immediately. I bought a new computer. It came installed with windows 7. I want to install xp. But whenever I boot from cd it shows an error. Windows encountered an error and set up needs to shut down. Check your hard disk for virus and corruption. Check if hard disk is configured properly. Uninstall any newly added hard disk. There are no viruses in my system. Kindly help me. Thanks in advance.
11-08-2011, 08:33 PM #2In The Zone
- Join Date
- Jun 2011
- Location
- Roorkee
- Posts
- 488
Re: Help to install xp
Please post your machine config to rule out any configuration problems with Windows XP.
Chances are your new hardware is optimised to work best with Windows 7.
And why do you want to run XP? Windows 7 is better than XP in almost every department. If you want to run legacy apps you may try XP mode(if you have Professional or Ultimate edition) or install XP in a virtual machine.
11-08-2011, 11:20 PM #3
@johnrambo4, try copy the content of the disc to your PC to check for CRC errors. maybe the disc is corrupted.
11-08-2011, 11:47 PM #4
First thing first: If your machine has came preinstalled with Windows 7, then it must be a Genuine licensed version. And if you are installing XP over it, it would most probably be Pirated.
Q: Now, do you REALLY want to lose a GENUINE LATEST VERSION of Windows with a DECADE OLD pirated Windows?
If answer to above question is Yes, then try SAM's method.
And if the disk is correct, try to Nuke Hard drive from s/w like, Darik's Boot And Nuke | Hard Drive Disk Wipe and Data Clearing And then try to install XP.
Disclaimer: After using DBAN, if you are unable to install XP, your computer might be unusable. Use at your own risk.
12-08-2011, 09:12 AM #5Right Off the Assembly Line
- Join Date
- Mar 2011
- Posts
- 12
Thank you dudes I will now use windows 7. I have ultimate version and I will download xp mode.
12-08-2011, 11:37 AM #6
with all the above users comments..
@johnrambo4: thats a wise decision of using windows 7 & not hampering the OS & system...
but still if u want to use XP in safer way then use VMWare Player to emulate it or VM as told by vigneshHTC One V | Nokia 5233 | Nikon D3100 | Apple Ipod Touch 4G | Sound Magic PL21 | Sound Magic ES18
14-08-2011, 01:16 PM #7Apprentice
- Join Date
- Apr 2007
- Posts
- 63
the only reason i use Xp is:
1. to run classical TC [c compiler]. i need it for my computer graphics lab.
2. oracle 9i not supported by windows 7
3. IBM RAD [not supported on win 7]Amit Dutt
14-08-2011, 02:32 PM #8
14-08-2011, 04:07 PM #9AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
15-08-2011, 12:27 AM #10Apprentice
- Join Date
- Apr 2007
- Posts
- 63
please suggest IDE for running C graphics
Amit Dutt
15-08-2011, 10:55 AM #11
ok, I will.
But first I want your teacher/professor to join this forum.
or better...just read this: C/C++ Beginner's Guide and Post Basic Questions hereAMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
15-08-2011, 11:02 AM #12
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
15-08-2011, 01:59 PM #13Apprentice
- Join Date
- Apr 2007
- Posts
- 63
true sir...
i never liked TC. but at college the Norm is TC only. previously in C++ programming course I used MS VC++ and referred Robert Lafore while college labs were using TC for C++ too.Amit Dutt
Can not install Win 7 on my SSD
By vyral_143 in forum Software Q&AReplies: 2Last Post: 03-05-2012, 03:05 PM -
Unable to Install Windows 7 , but able to Install Win xp ??
By nvrmndryo in forum Software Q&AReplies: 3Last Post: 07-08-2011, 01:52 AM -
How to install 98SE after install XP
By vikasg03 in forum Software Q&AReplies: 2Last Post: 11-02-2008, 01:42 PM -
how to install ubuntu direct from install menu rather than first run it thru live cd
By arunks in forum Open SourceReplies: 10Last Post: 31-08-2006, 10:41 PM -
How to install windows 2000(pro)After install of xp?
By rajas700 in forum Software Q&AReplies: 4Last Post: 23-10-2005, 01:32 PM
LinkBack URL
About LinkBacks
