Old 10-08-2011, 12:27 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
bobby23's Avatar
Default Auto start an application after closing another application
Is there a way for me to auto start ccleaner and automatically Run Cleaner after I close Google chrome every time?
bobby23 is offline   Reply With Quote
Old 10-08-2011, 12:37 PM   #2 (permalink)
saswat23's Avatar
Default Re: Auto start an application after closing another application
If you are using Windows7 then shedule this in the Sheduler.
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 10-08-2011, 12:49 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
I don't think there is a software which will do the same...
but one can create a win32 program using VB.NET or C# & applying the concept of threading
Old 10-08-2011, 12:52 PM   #4 (permalink)
Dust in the Wind
Skud's Avatar
If all you need to do is clear Google Chrome's cache, then I think every browser supports "clear cache on exit" sort of thing. Try looking in the settings.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is online now   Reply With Quote
Old 10-08-2011, 01:07 PM   #5 (permalink)
Sam is offline   Reply With Quote
Old 10-08-2011, 06:14 PM   #6 (permalink)
bobby23's Avatar
I have click & clean it does clear the cache but I am using win 7 and I have it pinned to the taskbar. So when I right click on chrome in taskbar it shows recently closed and most visited. I have to use ccleaner to clean it. Not only chrome but every thing pinned to the taskbar shows history, which I don't want.
@Zangetsu how do I do that??
Thx all
Old 10-08-2011, 06:25 PM   #7 (permalink)
Fullbring
Zangetsu's Avatar
Thx all
if u know vb.net & c# then only u can create a program in visual studio IDE.
u need to have thorough knowledge of the subject "Threading","Process" etc.
what the program will do is run in background & monitor chrome is running or not
& as soon as it is closed it will open CCleaner.but u have to design it that way.
but it will only open CCleaner & will not automate its inside process such as "RegCleaning" etc
Old 10-08-2011, 10:29 PM   #8 (permalink)
Stuck in Time...
Vyom's Avatar
I can't help you on how can you accomplish the Automatically running of CCleaner after some app, like Chrome closes, but I can help you in making that easier.
As, Zangetsu said, even if you could make such an app, "it will only open CCleaner & will not automate its inside process such as "RegCleaning" etc"
So, for that I would like to add, that CCleaner supports Command Line Parameters.
So, if you edit a shortcut of CCleaner by following command, just double clicking it, would automatically start the software, and would perform the cleaning.
CCleaner.exe /AUTO
Source:
CCleaner - Command-line parameters
CCleaner runs silently and automatically, using the current set of saved options to clean the PC. CCleaner then exits.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
Old 11-08-2011, 03:00 PM   #9 (permalink)
cute.bandar's Avatar
pretty sure this can be done with autohotkey. Try asking there: AutoHotkey Community - Mouse and Keyboard Macros and Hotkeys
Computer parts search Engine(for india) : http://goo.gl/Sg8Yv
cute.bandar is offline   Reply With Quote
Old 14-08-2011, 01:33 PM   #10 (permalink)
Your Ad here
nisargshah95's Avatar
Thumbs up Re: Auto start an application after closing another application
Exactly what I was thinking! I could have made an executable for you but I do not know your config. So here's the code you need for AutoHotKey -
RunWait chrome.exe
Run CCleaner.exe /AUTO   '[If Vineet369's command is right]
Type chrome.exe and CCleaner.exe along with their respective path names and then assign a hotkey for this script or just make an executable out of it (Autohotkey supports converting your scripts to exes. There's a separate program included for that). Next time you want to open Chrome, just open that exe itself.
“The Web is like a dominatrix. Everywhere I turn, I see little buttons ordering me to Submit.”
ASUS P5KPL AM/PS | P4 @ 3.07GHz | Ubuntu 11.04 / Win Server 2k8 / XP SP3 | 1GB DDR2 | Samsung HD080HJ 80GB
nisargshah95 is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/144940-auto-start-application-after-closing-another-application.html
Bat file openen zodra chrome afsluit This thread Refback 29-09-2011 07:57 PM
- by Niilesh
- by chris
- by gforz
- by Anorion
- by tkin
