Old 24-08-2005, 08:47 AM   #1 (permalink)
Default help system infected with Win32.pinfi virus.
My system infected with Win32.pinfi virus. can you plz give any software or tool to remove this virus, like you gave nme the Win32 anti parite virus remover tool. plz.
one more thing, when i boot my Win XP MCE, after entering my password my system stays like that onl;y for a miunte & then i get the desktop & nothing else. i have to open the windows task manager by pressing CTRL+ALT+DEL & in that i have to give a new task explorer.exe then my desktop loads. plz help me
Mangal Pandey is offline
Old 24-08-2005, 08:54 AM   #2 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Visit http://www3.ca.com/securityadvisor/n...aspx?cid=60045
for a tool to remove Pinfi virus.
For additional removal instructions usinf Norton Antivirus see
http://securityresponse.symantec.com...w32.pinfi.html
navjotjsingh is offline
Old 24-08-2005, 12:56 PM   #3 (permalink)
Just Do It
Charley's Avatar
Check this direct link
HERE
Charley is offline
- by Niilesh
- by chris
- by gforz
- by Anorion
- by tkin
