Old 04-08-2011, 10:54 AM   #1 (permalink)
Default Anybody using KM Player, need help
whenever i am trying to watch old encoded movies using KM Player, which had different audio channels (5.1, stereo, etc), i am not able to hear the voices, but only the music.
But, when i switched to VLC player and changed the audio channel to stereo i got everything i wanted...
Is there anyway of doing this same thing in KM Player, please advise.
*** I like KM Player becuase of its big subtitle and the full screen option (when pressing the key "6")
dinga03 is offline   Reply With Quote
Old 04-08-2011, 11:48 AM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: Anybody using KM Player, need help
KMP is a good player,and for the audio problem check with settings in options area.
changing to mono or Stereo etc
Old 04-08-2011, 03:01 PM   #3 (permalink)
@zangetsu.. i go to every option but could not find them, maybe they dont have that option. They have some option for the audio related thing, but not to change the channel
Old 04-08-2011, 07:55 PM   #4 (permalink)
Fullbring
Zangetsu's Avatar
ok...
in KMP do this -> Press F2 (to open preference box)
there under audio processing main root select -> resample/ouput -> under Output Box dropdown u can select the speakers u want 2.0,2.1,5.1 etc
Old 04-08-2011, 11:53 PM   #5 (permalink)
@zangetsu... thanks for the reply....
Now i listen to the audio using the Mono and Stereo option..
but when i use the 3/0 Three Front option, i got an error and my computer restarts by itself..
Anyway, thanks a lot.....
Old 05-08-2011, 04:26 AM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ what version of KMPlayer you are using ??
ToPsPeEeD = FaSt BuT StEaDy
Old 07-08-2011, 04:53 PM   #7 (permalink)
sorry for the late reply, got caught up in something..
my version is 2.9.4.1434
Old 08-08-2011, 03:11 AM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ The Latest version is 3.0.0.1441 - get it
- by Niilesh
- by chris
- by gforz
- by Anorion
- by tkin
