Old 03-08-2011, 08:54 PM   #1 (permalink)
Post MKV merge settings required
hi friends
i just downloaded mkv merge and i want to compress videos by using it but how should i enter the settings it is not easy as handbrake so can any body give me the settings or from anywhere i can get the *.mmg files to download
thank u
shrirangbhavsar is offline   Reply With Quote
Old 04-08-2011, 12:26 PM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: MKV merge settings required
@shrirangbhavsar: just go to videohelp.com there u will find the tutorial of mkvmerge & that wud solve your problem.
- by Niilesh
- by chris
- by gforz
- by Anorion
- by tkin
