Re: a folder got invisible . please help me...
do this :
1. open the run prompt by pressing "windows key + R"
2. Type "cmd" without quotes and press enter
3. at the command prompt, type "D:" without quotes and press enter.
4. then type the following command and press enter :
attrib software2 -s -h
Your folder will be visible after that.
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
