Old 27-07-2011, 02:07 PM   #1 (permalink)
Default USB Diskette on Key
in my note book (compaq presario v 3000) one of the boot preferences is USB Diskette on Key.
can somebody explain this boot option?
mahendran is offline   Reply With Quote
Old 27-07-2011, 04:54 PM   #2 (permalink)
Living to Play
gameranand's Avatar
Default Re: USB Diskette on Key
See This
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
gameranand is offline   Reply With Quote
Old 27-07-2011, 05:04 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
Originally Posted by gameranand View Post
See This
I think OP is asking about boot menu in BIOS & not the Disc on Key pendrive..
I guess its the feature to boot from USB or may be some access grant thru USB
Old 27-07-2011, 05:25 PM   #4 (permalink)
Living to Play
gameranand's Avatar
Oops my bad.
That option is to boot from a USB stick. It basically stores boot data on that stick so system won't boot unless its plugged in.
Old 27-07-2011, 07:19 PM   #5 (permalink)
with this boot option,can we boot with any usb device including a usb cd/dvd drive?
Old 27-07-2011, 08:28 PM   #6 (permalink)
Living to Play
gameranand's Avatar
No you can have just one boot disk not multiple disks. You'll configure a USB disk as a boot device and after that you can only boot with that device plugged in. Its not a new feature though. You can do the same from inside windows using some third party softwares.
Old 28-07-2011, 10:54 AM   #7 (permalink)
Fullbring
Zangetsu's Avatar
u can't use the same option to boot from CD/DVD.& also not any usb will work
coz the source USB shud be a bootable USB.
same theory applies to CD/DVD(bootable)
- by Niilesh
- by chris
- by gforz
- by Anorion
- by tkin
