26-07-2011, 06:25 PM
Adam young
firefox problem
guys when i use hardware acceleration option in firefox everything gets blurred and fonts won't be visible correctly but if i disable it everything works fine. why is so?
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
27-07-2011, 09:50 AM
Re: firefox problem
Sorry bit I cant seem to notice much difference with the screenshots
Try Reinstalling the browser, reinstalling GPU drivers.
27-07-2011, 03:14 PM
Re: firefox problem
^^ Add me in the list too i also could not figure any difference
@sukesh try re-installing the GPU Drivers
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
27-07-2011, 04:48 PM
Living to Play
Re: firefox problem
No different is there for sure. I can easily recognize it and its irritating also.
Try updating your video drivers and reinstalling as already suggested.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
27-07-2011, 05:33 PM
Fullbring
Re: firefox problem
@sukesh1090: both the screenshot are not differentiable....
from where u r setting h/w acceleration?
28-07-2011, 05:14 PM
Adam young
Re: firefox problem
i tried with all the drivers guys but the problem is not getting solved.i enable acceleration from mozilla options menu.here i have uploaded the images in imageshack,just compare the fonts in both the pictures you will see the difference.
-Rifleman's Creed
28-07-2011, 07:17 PM
Living to Play
Re: firefox problem
Maybe its a firefox bug. Use Firefox with that option disabled.
28-07-2011, 08:22 PM
Mozilla Rep
Re: firefox problem
Try this:- Type about:config into your address bar and promise Firefox you'll be careful.
- Type render in the search box, and find the following two keys:
gfx.font_rendering.directwrite.enabled
mozilla.widget.render-mode
- Double click on the gfx.font_rendering.directwrite.enabled entry so that it's set to true.
- Double-click on the mozilla.widget.render-mode entry and set the value to 6. If you can't find this key, right-click anywhere in the window, hit to New > Integer, set it's name to mozilla.widget.render-mode, and value to 6.
- Restart Firefox
To revert back, just go back into about:config, disable gfx.font_rendering.directwrite.enabled, and set mozilla.widget.render-mode to -1.
29-07-2011, 11:04 AM
Fullbring
Re: firefox problem
Firefox is already working perfectly for the OP with that option disabled...
29-07-2011, 12:01 PM
Re: firefox problem
R u using cleartype try disabling/enabling it & see
29-07-2011, 04:54 PM
Adam young
Re: firefox problem
thank you guys.
@sygeek,
i set true for directwrite but i can't find the other option.i am using mozilla 6 and i found in firefox forum that many of them are having this issue and it is due to the problem with directwrite font which is not rendering fonts correctly when acceleration enabled.
The same thing happens with even safari and Microsoft office 2010 when i disable the acceleration fonts gets cleared.
-Rifleman's Creed
29-07-2011, 05:05 PM
Mozilla Rep
Re: firefox problem
Just try and go with Firefox 5, FF6 is still in beta.
29-07-2011, 06:18 PM
Adam young
Re: firefox problem
thank you for the support guys.the problem solved just disabled the MLAA in CCC and the problem solved.
-Rifleman's Creed
29-07-2011, 07:27 PM
Fullbring
Re: firefox problem
this was commented by gameranand in post#7
31-07-2011, 10:49 AM
Adam young
Re: firefox problem
no its not firefox bug it is mlaa which tries to apply AA to the fonts also,because of which the fonts become blurry.
-Rifleman's Creed
