Old 26-07-2011, 12:21 PM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Lightbulb VLC player playback Issue...
I am using the latest version of VLC Player.
but all of my m2ts files are not being played in it.
but other players such as MPC,KM Players play m2ts files smoothly.
what is the problem with VLC?
Old 26-07-2011, 05:24 PM   #2 (permalink)
Default Re: VLC player playback Issue...
Did yiu try to Google
FAQ - Playback issues
vlc unable to open the m2ts - Google Search
Old 27-07-2011, 11:34 AM   #3 (permalink)
Fullbring
Zangetsu's Avatar
^did u checked in VLC playing m2ts files?which version are u using?
Old 27-07-2011, 04:49 PM   #4 (permalink)
Living to Play
gameranand's Avatar
LOL I don't have any *.m2ts file at all or I could have checked it for you. When I converted and then played VLC ran that finely though.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
gameranand is offline   Reply With Quote
Old 27-07-2011, 04:53 PM   #5 (permalink)
Fullbring
Zangetsu's Avatar
can u download a small sample .m2ts video & check it pls
Old 27-07-2011, 04:58 PM   #6 (permalink)
Living to Play
gameranand's Avatar
Give me a download link
I can do it for you of course.
Old 27-07-2011, 04:59 PM   #7 (permalink)
Stuck in Time...
Vyom's Avatar
It may be the case of VLC not supporting the specified format. Or source file being corrupt. Or some current VLC version problem. Try previous versions of VLC.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
Old 27-07-2011, 05:08 PM   #8 (permalink)
Fullbring
Zangetsu's Avatar
source file is not corrupt coz they r playing in MPC & KMPlayer.
& about VLC I dnt know whats the problem.
r u using the latest version?
I will try with old versions...
sorry yaar..dont know any.
if possible will google & tell u abt it.
Old 27-07-2011, 05:19 PM   #9 (permalink)
Living to Play
gameranand's Avatar
You can give me link for your source file as well. I'll download it even if its somewhat bigger.
Old 01-08-2011, 12:48 PM   #10 (permalink)
Fullbring
Zangetsu's Avatar
Ok now I have download an m2ts file (3.9GB) & its working in VLC Player but the other m2ts files were still having a problem with VLC...dont know what is the files..
Old 01-08-2011, 07:03 PM   #11 (permalink)
Living to Play
gameranand's Avatar
See the media info and see if everything matches or not.
Old 01-08-2011, 09:17 PM   #12 (permalink)
Fullbring
Zangetsu's Avatar
M2TS that worked in VLC:
Format : BDAV
Format/Info : Blu-ray Video
File size : 3.99 GiB
Duration : 1h 43mn
Overall bit rate : 5 512 Kbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : 27
Duration : 1h 43mn
Bit rate mode : Variable
Bit rate : 4 542 Kbps
Maximum bit rate : 25.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.091
Stream size : 3.36 GiB (84%)
Writing library : x264 core 105 r1732 2b04482
the one below didn't
Format : BDAV
File size : 4.36 GiB
Duration : 1h 37mn
Overall bit rate : 6 373 Kbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Codec ID : 27
Duration : 1h 37mn
Bit rate : 5 313 Kbps
Maximum bit rate : 18.0 Mbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.107
Stream size : 3.74 GiB (86%)
Writing library : x264 core 104 r1683 62997d6
Old 01-08-2011, 09:25 PM   #13 (permalink)
Living to Play
gameranand's Avatar
Both are same. Can't understand why one didn't.
Old 02-08-2011, 11:51 AM   #14 (permalink)
Fullbring
Zangetsu's Avatar
yeah..even I m confused both are identical
Old 02-08-2011, 12:31 PM   #15 (permalink)
Simply.. Evolution !!
TheMost's Avatar
^ What Kind'a prob ? VLC shows error message or playback glitches??
Damaged Files could be a prob !!
| Core2Quad Q6600 @ 2.40GHz, 4GB RAM |GeForce GTX 260 |
:???: BUSY BEEE :?
TheMost is offline   Reply With Quote
Old 02-08-2011, 12:43 PM   #16 (permalink)
Stuck in Time...
Vyom's Avatar
Well, if both the videos are identical, then the only reason which could explain the failure of playback of one video, has to be that the file itself is corrupt. It can happen because of incomplete download, or some file transfer error.
You can try re-encoding the video in question, to the same or similar format, by tool such as, AVIdemux.
Old 02-08-2011, 02:59 PM   #17 (permalink)
TheMost's Avatar
Zangetsu .. I am waiting for ur answer ///
:???: BUSY BEEE :?
Old 02-08-2011, 04:05 PM   #18 (permalink)
Fullbring
Zangetsu's Avatar
@TheMost & vineet369: The file is not corrupt. coz I can play those files flawlessly in MPC & KMPlayer.
Old 02-08-2011, 04:08 PM   #19 (permalink)
TheMost's Avatar
:???: BUSY BEEE :?
Old 02-08-2011, 04:13 PM   #20 (permalink)
Fullbring
Zangetsu's Avatar
^No error messages on screen...but nothing happens VLC remains idle....no black screen nothing...
Old 02-08-2011, 04:32 PM   #21 (permalink)
TheMost's Avatar
u Downloaded that ?? if so via torrents or HTTP / file hosting ??
:???: BUSY BEEE :?
Old 02-08-2011, 04:35 PM   #22 (permalink)
Fullbring
Zangetsu's Avatar
so is there any way to check whether a file is corrupt.
Let me tell u I have another m2ts file & that too not opening in VLC...
Old 02-08-2011, 04:42 PM   #23 (permalink)
TheMost's Avatar
No - The file ain't corrupt AFAIK !!!
prob with VLC .....
There are certain releaser groups who use Kind'a formats that fails to play in VLC .. They compress a Whole BR into 3/4GB ... Stunning
I mean 99.5% it passes sometimes ...
I'll come over private !
:???: BUSY BEEE :?
Old 02-08-2011, 04:43 PM   #24 (permalink)
Fullbring
Zangetsu's Avatar
prob with VLC .....
is VLC their foe..that it shud not support their files...
I guess only the VLC developer can troubleshoot this kind of issue...
I have searched vlc forums but no success..only post I got from person is to choose "ffmpeg" in advanced preference..now where is this option I dont get it?
Old 02-08-2011, 04:51 PM   #25 (permalink)
TheMost's Avatar
OK Now u got the answer na ??? ( Over priivate )
:???: BUSY BEEE :?
Old 03-08-2011, 02:25 PM   #26 (permalink)
Fullbring
Zangetsu's Avatar
Q: Does VLC player doen't use codec?I mean it has inbuilt codec?
Old 03-08-2011, 03:23 PM   #27 (permalink)
TheMost's Avatar
I Think Yes- It has ( I Guess )
But that's insufficient to play your video ...
That video even don't play in mine ... (VLC )
Even windows media player would play that - But VLC won't
:???: BUSY BEEE :?
Old 03-08-2011, 03:32 PM   #28 (permalink)
Fullbring
Zangetsu's Avatar
Yeah I have tried in WMP it played smoothly even in KMP it played well....
so the conclusion is VLC uses its own inbuilt codec pack whereas other players
WMP,MPC,KMP & GOM Player uses external codecs.
Old 03-08-2011, 03:38 PM   #29 (permalink)
TheMost's Avatar
^ I think so ... I Donno - wait for the experts to answer ...
BTW y do u wanna hang with VLC - Such a bad ass player ??
:???: BUSY BEEE :?
Old 03-08-2011, 03:41 PM   #30 (permalink)
Fullbring
Zangetsu's Avatar
VLC is most popular & widely used Player..so my concern was y it failed to play my files...
But for me its always MPC all time best....I even checked the BluRay videos in both players (VLC & MPC) & found that MPC gives better clarity,contrast & sharpness....
- by Niilesh
- by chris
- by gforz
- by Anorion
- by tkin
