Old 25-07-2011, 12:55 AM   #1 (permalink)
Exclamation Urgent help needed (DOS)
I copied some file from a Win Xp system having FAT32 file system to a hard disk connected as slave.
The hard disk has DOS installed as OS and have FAT as file system.
The content of folder I copied on to the hard disk is visible in windows system. But when I boot the hard disk in DOS only the folder is being made and the contents inside is not shown.
Please Help.
IN HOUSE GEEK!!!!!!!!!!!!!!!!!!!!
chirayu garg is offline   Reply With Quote
Old 25-07-2011, 07:08 AM   #2 (permalink)
Living to Play
gameranand's Avatar
Default Re: Urgent help needed (DOS)
Use Ubuntu Live CD and copy your data where you want. In Ubuntu if its there most probably it will show.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
gameranand is offline   Reply With Quote
Old 25-07-2011, 09:18 AM   #3 (permalink)
mithun_mrg's Avatar
Try using the Dir/a command & see
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 25-07-2011, 03:04 PM   #4 (permalink)
I'm a Wannabe Hacker
Prime_Coder's Avatar
yes, the dir /a command really works very well. you can view all files in the directory with this command. you can also provide attributes like dir /ah for looking hidden files or dir /as for looking system files.
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning. - Rich Cook
Prime_Coder is offline   Reply With Quote
Old 25-07-2011, 04:34 PM   #5 (permalink)
None of my files are hidden or have any other attributes, so above solutions are of no use.
I will explain again, the contents of the folder are visible in windows Xp when the HDD is connected as slave, but when I boot the HDD, it shows that only the folder is made and inside it no files are there.
Any more intelligent solutions ppl.
Old 25-07-2011, 04:45 PM   #6 (permalink)
mithun_mrg's Avatar
^^ what is the type & size of the files ur coping on ur DOS HDD
also the root folder in Fat16 can manage a maximum of 512 entries. The use of long file names can significantly reduce the number of available entries.
Old 25-07-2011, 04:46 PM   #7 (permalink)
Actually its an old DOS based software, contains some *.dat* , *.h* and one *.exe* file.
And the size of the entire folder is about 2mb and the size of the HDD is 128MB
Old 25-07-2011, 04:54 PM   #8 (permalink)
mithun_mrg's Avatar
I think u should use DOSBOX to run that on ur new PC rather then wasting time on the old 128MB HDD
Old 25-07-2011, 05:00 PM   #9 (permalink)
+1 to DOSBOX
I also wanted to suggest the same! Using the Dosbox on Windows XP will be useful.
@OP reply back after using DOSBox to let us know it the problem still persists.
Old 25-07-2011, 05:00 PM   #10 (permalink)
Fullbring
Zangetsu's Avatar
yes
Old 25-07-2011, 06:54 PM   #11 (permalink)
Living to Play
gameranand's Avatar
Yeah +1 for Dosbox.
- by Niilesh
- by chris
- by gforz
- by Anorion
- by tkin
