21-07-2011, 07:15 AM
#1 (permalink )
ADVAP132.dll was not found
recently,after the boot up an error message appears.
"this application failed to start because vADVAP132.dll was not found.reinstalling the same may solve the problem"
my os win xp pro sp3.
I have tried,sfc and reinstalling the ADVAP132.dll from a download source.
I am not able boot with xp cd for a repairing,eventhough bios is configured to boot so.
my cd drive of the note book is damaged as such using an external usb drive.
can anyone guide?
21-07-2011, 10:45 AM
#2 (permalink )
Fullbring
Re: ADVAP132.dll was not found
I guess to u can boot into desktop & encounter this message after that...
as the error message is self-explanatory but the DLL is of which application?
21-07-2011, 11:58 AM
#3 (permalink )
Living to Play
Try running in safe mode and if you can then restore your PC to previous state.
In war, Victory . In peace, Vigilance . In death, Sacrifice .
Lost my Mobile. Will be offline for quite some time. :(
21-07-2011, 12:33 PM
#4 (permalink )
Try these solutions mentioned here
Advapi32.dll - Advapi32.dll Not Found Error - Missing Advapi32.dll - Fix Advapi32.dll
i also think system restore should take care of the Problem
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
21-07-2011, 06:56 PM
#5 (permalink )
system restore wont work as it was turned off.
I had tried most of things suggested by mithun.after that only i had made the above post.
any other suggestion?
22-07-2011, 07:24 AM
#6 (permalink )
Try reinstalling SP3 and see
26-07-2011, 05:11 PM
#7 (permalink )
try reinstalling sp3 alone or entire os along with sp3?
26-07-2011, 05:12 PM
#8 (permalink )
Fullbring
Originally Posted by
mahendran
SP3 alone...
but if u have time then OS + SP3
27-07-2011, 02:03 PM
#9 (permalink )
I had re installed xp with sp3,but still same error.
27-07-2011, 02:27 PM
#10 (permalink )
Simply a DIGITian
I guess your source itself is corrupted.
Read The Forum RULES First.
Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
Before Starting A New Thread Read The STICKY THREADS First
Before Participating In Bazaar Section Read The BAZAAR RULES
27-07-2011, 02:28 PM
#11 (permalink )
Fullbring
krishnandu.sarkar
yes could be one of the reasons
27-07-2011, 05:17 PM
#12 (permalink )
Stuck in Time...
Try googling the missing file. And if you think its not necessary and doesnt hamper any other software then, use a startup manager like C cleaner to disable the app which needs it. It should stop the error to pop up, during system startup.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
27-07-2011, 05:18 PM
#13 (permalink )
Fullbring
vineet369
this is the system file of winXP SP2...
30-07-2011, 06:35 AM
#14 (permalink )
I have tried my best to avoid this annoying pop up during start up.
the above dll is there in my system 32. I had deleted the same and reinstalled again as suggested by google search.
I have c cleaner and can anyone tell me as to how can I disable this using ccleaner?
30-07-2011, 06:38 PM
#15 (permalink )
Mozilla Rep
Boot into windows setup with a USB and repair the partition.
01-08-2011, 05:41 AM
#16 (permalink )
sygeek
how to do that? could you please elaborate the proceedure?
18-09-2011, 12:12 PM
#17 (permalink )
finally I could remove the warning with the help of computer student.
a process was causing this and terminated the same in ms config
18-09-2011, 12:44 PM
#18 (permalink )
Dust in the Wind
Good to know your problem is solved. Can you elaborate on the steps?
Gaming Rig:
Spoiler :
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 ||
Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
Samsung Galaxy R I9103
Will be off/irregular for a month...
18-09-2011, 07:06 PM
#19 (permalink )
Fullbring
mahendran
pls give the steps followed if u know them
