hmm okay....
I have not done MCSE or any certification, nor I had taken any training but I just know some stuff by playing around..
There is somehting called as
Roaming Profiles, so using that option you can get this thing done and using group policies you can always define what to allow and what not to
so using roaming profiles, you can save the file on server only and everything will be synchronized when you boot and shutdown the machine...
Microsoft.com - they have loads of GOOD information on active directory with some examples and guides...
I hope this is what you wanted
Deep
