Old 14-07-2011, 01:55 PM   #1 (permalink)
U7karsh|ProtocolX
utkarsh007's Avatar
Default EFS certificate problem
hey ery1 due to some technical problems i reinstalled windows 7 on mah pc but forgot to decrypt a very important folder of mine. now i have the .pfx certificate but forgot the password. I have tried with all i can remember. Can anyone tell me of a software that can bruteforce it. I have used one software but it jus start and ends in a second
Even if anyone can provide me with a .txt file with all possible brue force combinations with minimum of 6 and max of 15 letters, my work will be done
Hell was full so i am back
utkarsh007 is offline   Reply With Quote
Old 14-07-2011, 04:35 PM   #2 (permalink)
BIOS Terminator
nims11's Avatar
Default Re: EFS certificate problem
its simple to generate brute force combinations using any programming language.
use BRUTUS (google it or get it from JUNE 2010 playware DIGIT DVD)
here is the ultimate dictionary word password list - Ultimate Password List - Area51 Archives.
nims11 is online now   Reply With Quote
Old 15-07-2011, 11:46 AM   #3 (permalink)
U7karsh|ProtocolX
utkarsh007's Avatar
paswword list did'nt worked. Still i am unable to get mah password
Old 15-07-2011, 12:36 PM   #4 (permalink)
BIOS Terminator
nims11's Avatar
using all brute force combinations would be useless.
even if you only consider lowercase characters composing 6-15 letters, there will be
1.74434972 × 10^21 possibilities which would be impractical.
the best option you have is to remember all the details of your password (length, characters used/not used, etc) to narrow down to a more practical password list.
Old 15-07-2011, 12:52 PM   #5 (permalink)
U7karsh|ProtocolX
utkarsh007's Avatar
can u tell me that after a format, if i use the old .pfx that was made by my os before reinstall, will it work. I mean is there a chance that after format, the .pfx shows wrong pass even for the correct one. Also my folder (encrypted one) was at desktop before format. I moved it to my D drive before format also backed up my .pfx to skydrive. so in this scenario will my .pfx work???
- by gforz
- by Anorion
- by tkin
- by Niilesh
