Old 13-07-2011, 10:02 PM   #1 (permalink)
Default Dual Boot Problem
I have windows XP installed on c: drive and windows 7 on e: drive. Everything was working fine but today when I restarted my computer the entry for windows 7 on boot menu has disappeared. Now I cannot log into windows 7 as there is no entry in boot menu for win 7, but I can log into windows xp. Please help.
Boot.ini file in drive c: has following statements:
;Warning: Boot.ini is used on Windows XP and earlier operating systems.
;Warning: Use BCDEDIT.exe to modify Windows Vista boot options.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /NOEXECUTE=OPTIN /FASTDETECT
c:\CMDCONS\BOOTSECT.DAT="Microsoft Windows Recovery Console" /CMDCONS
The recovery Console is installed for Windows xp. TY.
regmiee is offline   Reply With Quote
Old 13-07-2011, 10:41 PM   #2 (permalink)
Electronic.
Neuron's Avatar
Default Re: Dual Boot Problem
Use EasyBCD to add Windows 7 to the bootlist.Download it from Download EasyBCD 2.1 - NeoSmart Technologies
I don't always make sense,but when I do,I don't.
Neuron is offline   Reply With Quote
Old 14-07-2011, 08:58 PM   #3 (permalink)
Thanks Neuron I Used EasyBCD to add Windows 7 to the bootlist but still there was no entry for windows 7. I tried that a lot but still there was no entry for Win 7. Later I used Windows 7 disk again to repair the boot menu and the problem was solved. ty.
What about this Random Question thing? Every time I TRY TO POST SOMETHING (though this is my 3rd or 4th post since i joined this forum in 2004 I HAVE TO SEARCH THE F**KING ANSWER LOL.
Old 14-07-2011, 09:38 PM   #4 (permalink)
Electronic.
Neuron's Avatar
lol.Its a newly implied system to keep spammers away.
EasyBCD should have fixed the problem.I can't see why it didn't work.Anyway, its fixed now.Good.
Old 14-07-2011, 09:48 PM   #5 (permalink)
Fullbring
Zangetsu's Avatar
I also solved the same problem earlier using above method
- by gforz
- by Anorion
- by tkin
- by Niilesh
