Old 11-07-2011, 12:14 PM   #1 (permalink)
Simply.. Evolution !!
TheMost's Avatar
Default Auto Disconnect and connect from net !
Need a software to Auto Disconnect and connect from net at specific times to bypass trafic limits from file hosting services !
Using Win7 x64 bit !
| Core2Quad Q6600 @ 2.40GHz, 4GB RAM |GeForce GTX 260 |
:???: BUSY BEEE :?
TheMost is offline   Reply With Quote
Old 11-07-2011, 12:31 PM   #2 (permalink)
baiju's Avatar
Default Re: Auto Disconnect and connect from net !
Use a downloader like jdownloader.
baiju is offline   Reply With Quote
Old 11-07-2011, 12:42 PM   #3 (permalink)
TheMost's Avatar
^ Ok U mean that auto re-connect ??
It is awful ! I cannot follow that and shows error ... please another way !
:???: BUSY BEEE :?
Old 11-07-2011, 01:59 PM   #4 (permalink)
Living to Play
gameranand's Avatar
Jdownloader doesn't. At least give it a try whats the harm in that.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
gameranand is offline   Reply With Quote
Old 11-07-2011, 03:09 PM   #5 (permalink)
TheMost's Avatar
Struck at this .. Chrome says " page can't be displayed "
Atleast suggest some other software
:???: BUSY BEEE :?
Old 11-07-2011, 03:56 PM   #6 (permalink)
mithun_mrg's Avatar
If ur using PPPOE
U can use Rasdial command to connect to net automatically
use Rasdial.exe entryname "username" "password" for connection
& RAsdial.exe entryname /DISCONNECT
Type this in CMD for more info> rasdial.exe/?
entryname will be the name of ur PPPOE connection create two batch files one for Connect & one for Disconnect and schedule them to run from task scheduler at appropriate times
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 11-07-2011, 07:09 PM   #7 (permalink)
Freak Beta 1
Dark Core's Avatar
Try, FlexibleSoft Dialer XP PRO
Its Best IMO!
Dark Core is offline   Reply With Quote
Old 11-07-2011, 09:34 PM   #8 (permalink)
Stuck in Time...
Vyom's Avatar
Broadband FTW!
(sorry, dont have a suggestion, since I dont use one!)
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
Old 11-07-2011, 11:54 PM   #9 (permalink)
Project Halcyon V2.0
tkin's Avatar
Are you using pppoe dialer in windows? If so follow this post: Connect to PPPoe automatically
Works flawlessly, create the bat files, and use task scheduler to run them at specific times, I use task scheduler to run connect.bat file @ 2.10AM, then run utorrent 5 mins later and disconnect.bat @ 7.50AM. Never let me down.
Much better option that running 3rd party softwares.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline   Reply With Quote
- by gforz
- by Anorion
- by tkin
- by Niilesh
