Old 08-07-2011, 06:17 PM   #1 (permalink)
Simply.. Evolution !!
TheMost's Avatar
Default Cut mp4 , mkv
How to cut .mp4 / .mkv files without re-encoding ??
I mean the same exact Quality as b4 !
Paid/freeware
| Core2Quad Q6600 @ 2.40GHz, 4GB RAM |GeForce GTX 260 |
:???: BUSY BEEE :?
TheMost is offline   Reply With Quote
Old 09-07-2011, 05:24 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Cut mp4 , mkv
Use this - it's commercial app anyway
MKV Splitter
For a free alternative you can try this - but it might not cut/split mkv files
http://www.freevideocutter.com/
ToPsPeEeD = FaSt BuT StEaDy
Old 09-07-2011, 08:12 AM   #3 (permalink)
Living to Play
gameranand's Avatar
You can use Virtualdub but working on it is kinda complicated for newbie but has most features. And you should know that when you cut a video it gets encoded anyway so its the same deal. You can also use Format Factory for simple cutting and splitting. All the mentioned softwares are freewares.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
gameranand is offline   Reply With Quote
Old 09-07-2011, 11:09 AM   #4 (permalink)
TheMost's Avatar
Format factory will not re-encode ,,, rite ??
Thats what i want !
:???: BUSY BEEE :?
Old 10-07-2011, 07:38 AM   #5 (permalink)
Living to Play
gameranand's Avatar
Yes it will re encode it and save the file at your desired location.
Old 10-07-2011, 10:44 AM   #6 (permalink)
TheMost's Avatar
Re-encode ... Can i save without re-encoding ( That is what i want )
:???: BUSY BEEE :?
Old 10-07-2011, 12:40 PM   #7 (permalink)
Living to Play
gameranand's Avatar
That is simply impossible. Any software encodes any video file when you make changes. Here you are actually creating a whole new video and you expect to do that without encoding. No you can't. Just use Mediacoder as it will do this very fast because it uses Nvidia Cuda.
Old 11-07-2011, 12:10 PM   #8 (permalink)
TheMost's Avatar
No, I can't get u
WE have " Direct stream copy " with VdubMod and Avi trimmer rite ?
:???: BUSY BEEE :?
Old 11-07-2011, 01:50 PM   #9 (permalink)
Living to Play
gameranand's Avatar
Yup do that and see the file size. And also direct stream is nothing but encoding the file with same properties.
Old 11-07-2011, 02:59 PM   #10 (permalink)
TheMost's Avatar
^?? What ?? I Don't get u ....
I Cut a song , I get around 60 MB
:???: BUSY BEEE :?
Old 11-07-2011, 03:10 PM   #11 (permalink)
Living to Play
gameranand's Avatar
Yes it basically just re encode just that part of that video and thus you get the smaller size. There is nothing to be surprised of. Its that simple you see.
Old 11-07-2011, 03:58 PM   #12 (permalink)
TheMost's Avatar
^ anna , It hardly takes 5-10 secs and my eyes Don't notice ant Quality loss and technical properties seem same ....
The same way can i cut .mp4 / .mkv ??
:???: BUSY BEEE :?
Old 11-07-2011, 06:31 PM   #13 (permalink)
Living to Play
gameranand's Avatar
With Virtualdub yes with others mostly not. Virtualdub is best damn editing software I have seen. Although I don't do edits nowadays but there was time when I used to do that a lot and only used virtualdub. Also the reason behind this is your GTX 260 as virtualdub uses your GPU.
Old 11-07-2011, 08:24 PM   #14 (permalink)
Stuck in Time...
Vyom's Avatar
OP can also try AVIdemux, since I think it's one hell of a powerful tool to cut and merge videos of different formats.
I don't know if it uses your GFX like virtualdub, as described by gamernand, but I know this that you should give it a try.
It may seem a little overwhelming at first, but hell, some knowledge of basics of Videos properties is a must before using ANY video cutter/editor.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
- by gforz
- by Anorion
- by tkin
- by Niilesh
