Old 06-07-2011, 04:28 PM   #1 (permalink)
" It'S iN tHe GaMe..."
justme101's Avatar
Default Recycler virus!!! Help!
A friend of mine has the problem with this virus.
Any folder which i sent from my pc to a pendrive appeared normal in my pc but when it was plugged into my friend's pc the icon's of the folders changed into a shortcut icon but i can still open them. And there is a folder called "RECYCLER" which is also with a shortcut icon. When i took the pen drive and scanned it with avast from my pc.. ( i have attached a screenshot of the results....please see)..it found a WIN32:Malware -gen .. now i scan my friend's pc with avast and i get nothing in any of the drives...but the same thing continues to happen...
Any solution people?????
justme101 is offline   Reply With Quote
Old 06-07-2011, 05:05 PM   #2 (permalink)
mithun_mrg's Avatar
Default Re: Recycler virus!!! Help!
First install Microsoft Security Essentials in both PC's
Virus, Spyware & Malware Protection | Microsoft Security Essentials
Update
Get the latest definitions - Microsoft Malware Protection Center
Perform a Full Scan and also the pendrive, try to run the scan from SafeMode
U have to manually clean & restore the Pen Drive through Ms-Dos attrib command
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 06-07-2011, 07:21 PM   #3 (permalink)
Living to Play
gameranand's Avatar
Try avast boot time scan and Online scanners.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
gameranand is offline   Reply With Quote
Old 06-07-2011, 07:39 PM   #4 (permalink)
@justme101, give a quick scan with updated malwarebyte antimalware.
Old 07-07-2011, 03:27 PM   #5 (permalink)
If the above fail, use this online Antivirus-
HouseCall - Free Online Virus Scan - Trend Micro USA
- by gforz
- by Anorion
- by tkin
- by Niilesh
