Old 01-07-2011, 08:00 PM   #1 (permalink)
Red face [SOLVED] Advanced boot option not appearing
Hi,
I have just upgraded to windows 7 last week.The problem is when I am trying to hit F8 button and get into advanced boot options.I tried holding it down instead of repeatedly pressing it too ..tried everything possible, All the time only a screen appears that give me the option to select the boot device with 3 options(My HD, USB Drive and DVD). I can't get into safe mode.. Please help Me
I am having 32 bit with Intel i3
Last edited by krishnandu.sarkar; 01-07-2011 at 08:02 PM. Reason: removed unnecessary formatting
dhaneshka is offline
Old 01-07-2011, 08:18 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Advanced boot option not appearing
Go to MSCONFIG and set it. From the desktop.
asingh is offline
Old 02-07-2011, 12:40 AM   #3 (permalink)
Mozilla Rep
sygeek's Avatar
Press F12
sygeek is offline
Old 04-07-2011, 11:57 AM   #4 (permalink)
Smile Re: Advanced boot option not appearing
Pressing Space bar instead of F8 solved the problem
- by gforz
- by Anorion
- by tkin
- by Niilesh
