Old 30-06-2011, 05:32 PM   #1 (permalink)
quicky008's Avatar
Default Want to recover lost data-please help :(
I have lost around 5 GB of data from partition j of my hard drive.It appears that the files were deleted accidentally.This data is very important to me-i'll be in great trouble if i am unable to recover it.Among the lost data,there was a large .iso file that i require urgently.I have tried using various recovery softwares like Undelete plus,stellar data recovery etc but to no avail.Will it be possible for me to recover the lost data?Please help,this is a matter of great urgency!
quicky008 is offline
Old 30-06-2011, 07:54 PM   #2 (permalink)
Default Re: Want to recover lost data-please help :(
If you have not done any read-write operations on the disk where the files where deleted you you may be able to retrieve some data by using certain recovery software which may cost you a bomb. It may be better if you hand over the disk to a qualified computer technician without doing any more activities on the disk. Even then chances of getting corrupted files is quite high.
Anyway best of luck.
Vignesh B is offline
Old 30-06-2011, 09:07 PM   #3 (permalink)
quicky008's Avatar
I have scanned the affected partition with various recovery utilities but none of them could find the missing files (
Old 02-07-2011, 10:39 AM   #4 (permalink)
Which utilities have you used? If all of them cant find. Sorry your files are gone
thetechfreak is offline
Old 02-07-2011, 01:13 PM   #5 (permalink)
127.0.0.1
mitraark's Avatar
Use File Scavenger 3.2 . Check PM.
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
mitraark is offline
Old 03-07-2011, 02:28 PM   #6 (permalink)
I'm a Wannabe Hacker
Prime_Coder's Avatar
Use TestDisk First!
To recover deleted files, you can use FormatRecovery!
You can also opt for Data Rescue by Prosoft, which works in Linux!
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning. - Rich Cook
Prime_Coder is offline
Old 04-07-2011, 12:52 PM   #7 (permalink)
Try GetDataBack. I have very good experience with it. But its not freeware...
ispote is offline
Old 07-07-2011, 12:15 PM   #8 (permalink)
It is possible to recover lost data and files through data recovery softwares once i used Kernel for FAT and NTFS hard disk data recovery software for the recovery of deleted data and files from my hard drive which was accidentally deleted by me and then i used it, it recovered all my data instantly. It has a user friendly interface in which user can preview your data and files in scan mode and has the choice to save all at once or some selective files to your location. It can recover data from hard drives. flash drives, memory cards etc.
BakerCook is offline
Old 08-07-2011, 03:13 PM   #9 (permalink)
ajayritik's Avatar
Guys yesterday I accidentally deleted one of the video files which I want to recover. I have used Undelete Plus but didn't get the required file. Can anybody suggest a good program which can recover the file.
ajayritik is offline
Old 09-07-2011, 08:29 AM   #10 (permalink)
Living to Play
gameranand's Avatar
What was the size of the video??? Also have you done any read write operation after you deleted it ???
If the file size was big then its hard to get it back smaller files are easier to recover.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
gameranand is offline
Old 09-07-2011, 09:58 PM   #11 (permalink)
ajayritik's Avatar
Size of the video file is 4 GB.
Old 10-07-2011, 07:36 AM   #12 (permalink)
Living to Play
gameranand's Avatar
If size is this big then I don't think you'll be able to recover it.
Old 11-07-2011, 04:35 AM   #13 (permalink)
Fast 'N' Furious
topgear's Avatar
I've recovered dual large video files from vanished partition using Easeus Data Recovery wizard pro but it's a paid app anyway
EASEUS Data Recovery Wizard.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 11-07-2011, 02:57 PM   #14 (permalink)
ajayritik's Avatar
Found that my friend still has the movie with him so will take it from him. It's actually a 4 GB Blu ray rip of Avatar.
Old 12-07-2011, 03:47 AM   #15 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ WoW - it's solved so easily and It's always a good practice to have a backup
topgear is offline
- by gforz
- by Anorion
- by tkin
- by Niilesh
