Old 29-06-2011, 09:26 PM   #1 (permalink)
Default System not installing any OS
One of my friends have a Toshiba laptop Satellite Pro C650, and it was installed with Windows 7 Ultimate 32-bit. A few days back, there was a problem with the system, where, the system hanged when the Starting Windows screen appeared. After a few days the system, just crashed, and I my friend did a Windows recovery. After that the computer was running smoothly. After a few days again, the system again began giving the same problem, and then the system crashed. So I recommended that he format his computer and do a clean installation of Windows.
So, when he began the installation process of Windows 7 32-bit, the system again, freezed at “Setup is Starting” screen. Again, he tried it after restating the system, and again the system freezed, at “Setup is Starting”. I tried, to install from various media, but the screen froze, at there. I tried a mem test, and no hardware errors were found. Even I tried installing Ubuntu 10.04, and the system froze while it was loading the files, and a boot prompt came, and nothing happened. I tried with Ubuntu 10.10, and Kubuntu 10.04, and the same result.
Please advice what should I do.
paul.soumyabrata is offline   Reply With Quote
Old 29-06-2011, 10:39 PM   #2 (permalink)
Stuck in Time...
Vyom's Avatar
Default Re: System not installing any OS
Looks like a hardware error.
Are you sure RAM is ok? Have you tried another stick of RAM?
Also make sure, there is proper cooling. i.e, heat sink is working properly.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
Old 29-06-2011, 10:46 PM   #3 (permalink)
Dust in the Wind
Skud's Avatar
Is the Windows 7 pre-installed or you have installed it separately?
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is online now   Reply With Quote
Old 29-06-2011, 11:19 PM   #4 (permalink)
First of all, if I try to open the RAM sticks, I will void warranty.
Secondly, the temperatures are perfectly fine, and the heat sink is working properly.
Windows 7 was pre-installed.
Old 29-06-2011, 11:45 PM   #5 (permalink)
Dust in the Wind
Skud's Avatar
If possible do a startup repair. Otherwise OEMs generally have a hidden partition for OS recovery, go through the manual, and launch the recovery/reinstall process through it.
Gaming Rig:
HTPC Rig:
Old 29-06-2011, 11:48 PM   #6 (permalink)
I have already wiped my HDD, clean, and when I try to boot from my HDD, it display a message that BOOTMGR not found, Press Ctrl + Alt + Del, to restart. It is because I have no OS on my HDD.
Old 29-06-2011, 11:58 PM   #7 (permalink)
Dust in the Wind
Skud's Avatar
Does your laptop comes with any OS disk?
Gaming Rig:
HTPC Rig:
Old 30-06-2011, 12:07 AM   #8 (permalink)
First of all it my not my laptop, it is my friends. Secondly, it did not come with any shipped OS disc.
Old 30-06-2011, 12:07 AM   #9 (permalink)
Stuck in Time...
Vyom's Avatar
I failed to realize it was a laptop.
I recommend you take the laptop to service, since it's under warranty, and most probably this is a hardware issue (confirmed by the fact, that no OS including Linux is able to install).
Old 30-06-2011, 12:10 AM   #10 (permalink)
Yeah, that is what I feel too, I have also advised my friend to take it to service center. Tried, different OS, and all failed to install! Have any of you faced any such problem earlier?
Old 30-06-2011, 12:32 AM   #11 (permalink)
Dust in the Wind
Skud's Avatar
I recently faced such problem when while installing LibreOffice the system hangs and a cold boot just keep on showing the OS (Vista) failed to start screen. I tried startup repair from the boot menu a couple of times, it just hanged. Tried Ubuntu Live CD - it started up after 3-4 tries but failed to recognize the HDD. Then tried a separate Vista disk (not the one that comes with the Lappy). It hangs a couple of times, then finally allow me to select Startup Repair, but couldn't do a system restore as the HDD was not recognized. Just out of desperation tried the auto startup repair option and it worked.
Only problem is that during booting sometimes chkdisk start checking the hidden recovery partition and reports some corrupt MFT, but otherwise the system is working flawlessly.
I have Sony VAIO btw.
In your case as you have already wiped the HDD, so its better to take it to the service center and get the OS installed. They might find some other problems also.
Gaming Rig:
HTPC Rig:
Old 30-06-2011, 08:14 AM   #12 (permalink)
mithun_mrg's Avatar
Take it to the Sevice Center for RMA
Allied Digital Services Ltd. (C/O Digicomp Services LtdBack to Available Service Center List Company Name: Allied Digital Services Ltd. (C/O Digicomp Services Ltd Rating:
Address: 1st Floor , 49B C. R . Avenue
Opp. Jogajog Bhaban Main Phone: +91-33-40077906
City: Kolkata Toll-Free:
State/Province: Fax:
Mail Code: 700012 Email: kolkata@digicompindia.com
Company Name: inTarvo Technologies Limited Rating:
Address: 2 Ripon Street ,Mezzanine Floor Main Phone: +91-33-22277891/92/93
Mail Code: 700016 Email: pc.kolkatta@intarvo.com
Country: IN Web:
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 30-06-2011, 10:28 PM   #13 (permalink)
Guys after some, hard effort, I finally booted into the system, and guess what Linux(Kubuntu 10.04 LTS) could not even recognise the HDD. I suspect that there is a bad sector error, and referred to get an RMA. Lets see what happens, and will let you all posted.
Old 02-07-2011, 01:32 PM   #14 (permalink)
Guys, kept my friends laptop running for 12 hours, with the Windows 7 Ultimate (32-bit) Installation Disc, and finally, it started to install the OS. Now guess, what I went out for 3 hours, and came back to see, that the main power had been shut down by someone, and the laptop naturally ran out of juice.
Got to sit it with again, just so frustrating!
Old 02-07-2011, 02:21 PM   #15 (permalink)
Dust in the Wind
Skud's Avatar
Patience is the key, but I sympathize with you, I have been through this a couple of times. And what happened to taking it to Service Center, RMA etc.?
Gaming Rig:
HTPC Rig:
- by gforz
- by Anorion
- by tkin
- by Niilesh
