Old 29-06-2011, 09:21 PM   #1 (permalink)
Living With Light
gaurav.singh's Avatar
Exclamation Adobe Reader font problem
hi
I have some hindi pdf documents. When I open them with adobe reader, instead of reading the way it should it looks like gibberish which we see when we try to type hindi without in krutidev010 without selecting the proper font.
the document properties show the font support of krutiDev010 and this font is installed on my computer. Any help will be appreciated.
gaurav.singh is offline   Reply With Quote
Old 29-06-2011, 10:04 PM   #2 (permalink)
Dust in the Wind
Skud's Avatar
Default Re: Adobe Reader font problem
From where do you get the documents? The font might not be properly embedded.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is online now   Reply With Quote
Old 29-06-2011, 10:45 PM   #3 (permalink)
Living With Light
I'd downloaded those documents from a mp gov website a few months ago. Then they looked alright but today after an interval of a month they seemed like crap.
It may be worth mentioning that I reinstalled windows in this interval.
Old 29-06-2011, 11:06 PM   #4 (permalink)
Dust in the Wind
Skud's Avatar
Is it Win 7 64-bit?
Gaming Rig:
HTPC Rig:
Old 30-06-2011, 12:09 AM   #5 (permalink)
Living With Light
Originally Posted by Skud View Post
Is it Win 7 64-bit?
No, it's 32 bit win 7 ultimate.
Old 30-06-2011, 12:22 AM   #6 (permalink)
Dust in the Wind
Skud's Avatar
Check if the font is installed or not. Redownload the documents if possible and see if render properly.
Gaming Rig:
HTPC Rig:
Old 30-06-2011, 07:21 AM   #7 (permalink)
Try an alternate reder like Foxit
Link:
Foxit Reader - Overview - Foxit Software
Also try redownloading files.
Old 30-06-2011, 08:03 AM   #8 (permalink)
mithun_mrg's Avatar
Try Unistall & reinstalling the font
1.Open Fonts by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Fonts.
2.Click the font that you want to uninstall. To select more than one font at a time, press and hold down CTRL while you click each font.
3.On the File menu, click Delete.
To Install
2.Click File, and then click Install New Font.
If you don’t see the File menu, press ALT.
3.In the Add Fonts dialog box, under Drives, click the drive where the font that you want to install is located.
4.Under Folders, double-click the folder containing the fonts that you want to add.
5.Under List of fonts, click the font that you want to add, and then click Install.
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 30-06-2011, 11:53 PM   #9 (permalink)
Living With Light
sorry for replying so late but my internet connection was bit erratic. By the way I have tried reinstalling the font, redownloading the files as well as alternate reader ie. Foxit. None of these seem to work. The site I opened though looks fine in opera as it has hindi fonts too.
Old 30-06-2011, 11:57 PM   #10 (permalink)
Wise Old Mouse
mrintech's Avatar
Share the PDF file with US, if there's NO problem
- MrinTech :)
mrintech is offline   Reply With Quote
Old 01-07-2011, 05:55 AM   #11 (permalink)
Yup pls share with us. Put it at a free file sharing site like: Ge.tt
and copy paste the link here
Old 01-07-2011, 07:08 AM   #12 (permalink)
Dust in the Wind
Skud's Avatar
Give us the links of the site and the file.
Gaming Rig:
HTPC Rig:
Old 02-07-2011, 01:10 AM   #13 (permalink)
Living With Light
hey guess what! Today I opened the documents again, and out of the blue, I don't know how, they were alright!
I'd still post the files in mediafire.com and give you the links tommorrow if you are interested.
The from which the forms were downloaded is Ladli Laxmi Yojna (it's an mp gov site)
Thanks
Old 02-07-2011, 07:41 AM   #14 (permalink)
Thread [SOLVED]
anyways will try to open them
Old 03-07-2011, 09:48 PM   #15 (permalink)
Living With Light
hi,
I've uploaded the offending documents if anyone is interested though they are responding OK now.
I'd had same problem a year ago but then I'd just discarded the files and used hard copies.
Thanks for the final time
Old 29-09-2011, 11:22 AM   #16 (permalink)
hi,
Any update on this?
I have the same problem and the text I can see is as follows:
vkaxuokM+h {ks=z dh tul[a ;k dk fooj.k ¼loZs jftLVj ds vuqlkj½
Would appreciate some help with this.
I have tried Foxit Reader as well and no luck.
KoolPal is offline   Reply With Quote
- by gforz
- by Anorion
- by tkin
- by Niilesh
