Old 28-06-2011, 10:41 PM   #1 (permalink)
On KillingSpree!!!
scavanger007's Avatar
Default registry cleaning safe?
I m planning to clean my registry in an attempt slightly boost the speed of pc. I have never done this before.
Any precautionary advice, suggestions?
OS: Win 7 x64
No matter how much time u spent climbing up, u may still fall in an instant. -Max Payne 2
scavanger007 is offline   Reply With Quote
Old 28-06-2011, 10:43 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: registry cleaning safe?
Nothing, but don't manually clean it. I'd suggest to use CCleaner - Optimization and Cleaning - Free Download
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline   Reply With Quote
Old 28-06-2011, 10:49 PM   #3 (permalink)
On KillingSpree!!!
so is it completely safe to clean as per the scanning of the respective software....
Old 28-06-2011, 10:53 PM   #4 (permalink)
No, not completely safe.
Faun is offline   Reply With Quote
Old 28-06-2011, 10:56 PM   #5 (permalink)
On KillingSpree!!!
can u elaborate...
any bad experience of your's?
Old 29-06-2011, 01:18 AM   #6 (permalink)
Project Halcyon V2.0
tkin's Avatar
Why would you want to clean it? Registry slow down is a myth, modern windows os(7) manages the registry perfectly, if you have an issue you can try to modify the registry but do not clean it.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline   Reply With Quote
Old 29-06-2011, 06:19 AM   #7 (permalink)
Clean it if you are experiencing some glitches related to extension icons and file associations.
and use CCleaner. It is free and safe. Ideally, take save back-up when CCleaner asks.
Don't mess around manually with Regedit.exe unless you know what you are doing. Registry is one of the reason why Windows sucks - single point of failure.
Old 29-06-2011, 10:20 AM   #8 (permalink)
On KillingSpree!!!
oh, thanks for the feedback guys...
I guess, I m dropping the idea then
Old 29-06-2011, 10:24 AM   #9 (permalink)
In Shameful Misery
Scientia Wiz's Avatar
Cool Re: registry cleaning safe?
If we backup our registries then nothing insecure !
A Sci Wiz HERE ! .............. Believe it or not
Scientia Wiz is offline   Reply With Quote
Old 29-06-2011, 10:27 AM   #10 (permalink)
Super Moderator
asingh's Avatar
You can do it. I use CCleaner once a fortnight. Take a backup. Via CCleaner or manually.
asingh is offline   Reply With Quote
Old 29-06-2011, 10:50 AM   #11 (permalink)
In Shameful Misery
Wink Re: registry cleaning safe?
Yes to maintain your PC properly use CCleaner and put it on the startup mode an d whenever you will boot your PC then it will clean all your registries and the startup !
Old 29-06-2011, 11:42 AM   #12 (permalink)
Living to Play
gameranand's Avatar
Well its entirely safe. I do this all the time and sometimes I get the performance boost I mean sometimes when I do defrag, cleaner and all that ten game loading times reduces.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
gameranand is offline   Reply With Quote
Old 29-06-2011, 01:08 PM   #13 (permalink)
safe till you use the recommended apps & don't try to do it manually. i have TuneUp Utilities & CCleaner installed. Tuneup does autocleanup ever 4-5 days inc registry.
but from what i have seen it doesn't increase performance much. just solves some small problems. instead defrag registry & your drives.
Old 29-06-2011, 02:22 PM   #14 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
adding to above posts is that most people still go ahead and re-install entire OS if anything goes wrong with registry, actually it can be fixed using recovery option (by running installation CD/DVD).
My personal blog - http://gagan.scholarguru.com
gagan007 is offline   Reply With Quote
Old 29-06-2011, 02:56 PM   #15 (permalink)
Personally I have never had any problems with registry cleaners, neither any major performance boost.
But to be on the safer side take a backup of your registry and then do the cleaning by using known softwares like Ccleaner or Glary Utilities.
Vignesh B is offline   Reply With Quote
Old 29-06-2011, 06:25 PM   #16 (permalink)
i have 1 small doubt:
you take backup of registry, clean registry using some cleaner & it deletes some important keys & you end up with an unbootable system. will that backup be of any use?
Old 29-06-2011, 07:22 PM   #17 (permalink)
If the system becomes unbootable, then there is no use.
But the use comes when, say a software doesn't work after registry cleaning, then you can use that backup.
Old 29-06-2011, 08:36 PM   #18 (permalink)
Super Moderator
asingh's Avatar
Doubt it would reach that severity. Usually an applications(s) stops responding. Just double click the .reg to over ride.
Old 29-06-2011, 11:29 PM   #19 (permalink)
Stuck in Time...
Vyom's Avatar
I like Registry Cleaning, even if it's a myth. Makes me feel like, I am brooming the OS
Never had any problems, related to registry cleaning. I do a registry clean at least twice a month.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
Old 29-06-2011, 11:45 PM   #20 (permalink)
tkin's Avatar
I never cleaned the registry in my last OS(XP), ran it straight for 3 yrs without any significant hitch, just a few bad drivers, some manual cleaning and system restore saved my @$$. I never had to do any reinstall or repair, same with win 7, ran it for about an year or so without any issue, after which I upgraded the hardware.
Old 30-06-2011, 12:09 AM   #21 (permalink)
Stuck in Time...
Vyom's Avatar
Even I can live w/o cleaning my living room for months. But a little cleaning helps in keeping the room organized, for me and for other guests who sometimes come to visit me
Hoping that someone got the point.
Old 30-06-2011, 12:10 AM   #22 (permalink)
@Vignesh & Anil sir. thanks for clearing my doubts.
Old 30-06-2011, 11:21 AM   #23 (permalink)
Fullbring
Zangetsu's Avatar
OS: Win 7 x64
the registry grows in size as u work on PC daily...
so to optimize it apps are required...
just use CCleaner + Tune Up 2011 and you will never face any issue of reg crash
- by gforz
- by Anorion
- by tkin
- by Niilesh
