Old 25-06-2011, 05:14 PM   #1 (permalink)
Smile Need help guys.... vlc playr problm..
this is my pc configuration intel core 2 duo E7300@2.66GHZ, 2.66GHZ n 2gb ddr2 ram n 320gb samsung hd and 160gb seagate hd and creative 5.1 channel..
i encoded a video of size 2.2gb file to 900mb with megui encoding source the problm is whn i m playing the encoded video in my vlc playr it was showing a greenscreen .. bt the same file when i opend with windws playr r media classic player it is showng the video..... and in othrs pc the vlc is showng the video.... and my othr videos are also opening in vlc xpect the encoded video bt in my pc only it was showng the greenscreen pls help me y in my pc i m nt geting the video through vlc.... many times i encoded different videos and too many tyms reinstal of vlc also bt i dont get the video on my vlc playr ....
u4upendra is offline   Reply With Quote
Old 25-06-2011, 07:42 PM   #2 (permalink)
Default Re: Need help guys.... vlc playr problm..
What version you are using?
I used to play .flv files without any trouble in vlc1.1.7 but then updated to latest and had trouble with them so I reverted back and the trouble was gone.
Abhinav
abhinav_sinha is offline   Reply With Quote
Old 26-06-2011, 11:27 AM   #3 (permalink)
abhinav i m using latest version vlc 1.1.10
Old 26-06-2011, 12:03 PM   #4 (permalink)
Cool Buddy's Avatar
try the portable version of VLC media player once, if there's some problem with the configuration, it won't go away by reinstalling. But the portable version will have independent settings, so it might be able to play the file
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is online now   Reply With Quote
Old 26-06-2011, 12:08 PM   #5 (permalink)
Fullbring
Zangetsu's Avatar
@u4upendra: in vlc press ctrl + M for messages & change verbosity level to 1...
then play the video & check the messages..it will show error if any
if u change the level to 2 & play the video u will see another big list there
Old 26-06-2011, 12:12 PM   #6 (permalink)
Then I suggest to go for an older one. Either 1.1.7 or 1.1.5 as the case might be like mine.
Also see for the portable version
Abhinav
Old 26-06-2011, 02:16 PM   #7 (permalink)
@abhinav thnks dude it is playing vlc 1.1.9 bt i dont knw wat the wrng with 1.1.10
@Zangetsu i tried with vlc 1.1.10 level 1 some eror shown bt in level 2 a big msg came how can i correct that one dude.. the video is playing vlc 1.1.9 ... bt not in vlc 1.1.10 how can i correct the error...
Old 26-06-2011, 04:55 PM   #8 (permalink)
No problem!
Abhinav
- by gforz
- by Anorion
- by tkin
- by Niilesh
