Old 24-06-2011, 08:43 PM   #1 (permalink)
Default Help!!!! Deleted Partition
I wanted to delete two logical partitions but unfortunately i ended up in deleting every logical partition. Please help me i want my data back. Its very important data.
adwait111 is offline   Reply With Quote
Old 24-06-2011, 08:51 PM   #2 (permalink)
God of Mistakes...
Garbage's Avatar
Default Re: Help!!!! Deleted Partition
Try TestDisk - CGSecurity
It worked for me all the times.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline   Reply With Quote
Old 24-06-2011, 08:53 PM   #3 (permalink)
Thanks
Old 24-06-2011, 09:42 PM   #4 (permalink)
Living to Play
gameranand's Avatar
If new data has not been written on that sector yet then you might get your data so don't copy data yet. Just install the software suggested and try to recover the data.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
gameranand is offline   Reply With Quote
Old 25-06-2011, 06:24 AM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
USe Easeus Data Recovery app - it should recover your lost partitions - it saved my data a couple of times
here's the link :
http://www.easeus.com/datarecoverywizard/
ToPsPeEeD = FaSt BuT StEaDy
Old 25-06-2011, 01:49 PM   #6 (permalink)
BIOS Terminator
nims11's Avatar
^^ +1
i once accidently deleted the drive having all my works and then EASEUS recovered it successfully
nims11 is online now   Reply With Quote
- by gforz
- by Anorion
- by tkin
- by Niilesh
