Old 22-06-2011, 05:06 PM   #1 (permalink)
Pravas's Avatar
Thumbs up Having Problem Removing Entry From Add/Remove Program
I want to remove an entry from Add/Remove program and I tried various methods with Registry editing and few third partly software but it wont work.
While Registry and Thirdpartly tricks are working well on other softwares. But For some reason it won't work on the sotware that I want to be removed.
Please if someone has suggestion let me know. By the way the software name is "Autodesk Maya 2010"
Thanks.
!!!!*Little Knowledge Is Dangerous*!!!!!
Pravas is offline   Reply With Quote
Old 22-06-2011, 05:38 PM   #2 (permalink)
Mozilla Rep
sygeek's Avatar
Default Re: Having Problem Removing Entry From Add/Remove Program
Use Revo Uninstaller.
sygeek is offline   Reply With Quote
Old 22-06-2011, 10:15 PM   #3 (permalink)
Living to Play
gameranand's Avatar
You just want to remove the entry or want to uninstall the software???
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Lost my Mobile. Will be offline for quite some time. :(
gameranand is offline   Reply With Quote
Old 22-06-2011, 11:37 PM   #4 (permalink)
Pravas's Avatar
Lightbulb Re: Having Problem Removing Entry From Add/Remove Program
I just wish to remove the entry(Name). Otherwise I want the software to run as it is.
@Sygeek.
I've tried revo uninstaller. I tried to delete the entry from there, but the entry just got removed from Revo Uninstaller interface. I mean the entry was still there in windows add/remove program.
Old 22-06-2011, 11:55 PM   #5 (permalink)
Living to Play
gameranand's Avatar
Try this
or try using Add remove Cleaner software.
Old 23-06-2011, 01:00 AM   #6 (permalink)
Super Moderator
asingh's Avatar
Use CCleaner to fix the registery. Should be able to remove than.
asingh is offline   Reply With Quote
Old 23-06-2011, 01:39 AM   #7 (permalink)
Mozilla Rep
sygeek's Avatar
@Sygeek.
Use Advanced Uninstall. Do you want to just uninstall the entry or the whole program with it?
Old 23-06-2011, 07:18 AM   #8 (permalink)
Living to Play
gameranand's Avatar
He just want to remove the entry from Add or Remove Programs in Control panel he don't want to uninstall the software.
Old 23-06-2011, 10:56 AM   #9 (permalink)
Wise Old Mouse
mrintech's Avatar
Try this
Thanks
Great Info. out there
- MrinTech :)
mrintech is offline   Reply With Quote
Old 23-06-2011, 11:36 AM   #10 (permalink)
also try Your Uninstaller. its a trial. so just try once. it may work.
Old 23-06-2011, 01:53 PM   #11 (permalink)
Pravas's Avatar
@asingh
Thanks, I've used CCcleaner and it showed me an error like "Cannot Delete MSI installer". At least this made some sense while other software's were deleting it silently.
@gamerananad
Thanks, I've tried the web trick earlier it was of no help here. And also while using Add remove Cleaner, the program name itself was not listed there Cuz I suspect it was due to the face I've tried other software's to remove it.
So I think I came up with a work around, I may change it's name to some other Microsoft update ....lol...
But more Suggestion are welcome
Old 23-06-2011, 02:52 PM   #12 (permalink)
Dust in the Wind
Skud's Avatar
Is some autodesk service running in the background, which might be preventing from deleting its entries from registry?
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is online now   Reply With Quote
Old 23-06-2011, 04:24 PM   #13 (permalink)
Pravas's Avatar
I guess not, no such services with Autodesk or Maya running. Could you throw some light as to why it would need some background programs running? Then I may be able to find..
Old 23-06-2011, 04:46 PM   #14 (permalink)
First restart your computer and then try to install the software. If nothing happens, Tune Up Utilities can help you probably.
GPS: The best way to navigate safely and securely.:smile:
rajeevk is offline   Reply With Quote
Old 23-06-2011, 07:02 PM   #15 (permalink)
Dust in the Wind
Skud's Avatar
No idea. But sometimes it might just happened there's are something running in the background to protect the important files and settings like AV software. See the Image path of processes in task manager if something is pointing towards the Autodesk installation.
Gaming Rig:
HTPC Rig:
Old 23-06-2011, 07:14 PM   #16 (permalink)
I'm a Wannabe Hacker
Prime_Coder's Avatar
Have you tried through Windows RegEdit really and finding for Autodesk Maya 2010?
If not, first take a backup of windows registry and follow thisWindows 7)
Start RegEdit from Windows Run.
Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Uninstall
Find "Autodesk Maya 2010" using Find option from Edit menu. If you get any result, then delete that entire key from the left pane.
If this also doesn't help, then try using Glary Utilities, may be it will be helpful to you.
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning. - Rich Cook
Prime_Coder is offline   Reply With Quote
Old 24-06-2011, 10:06 AM   #17 (permalink)
Pravas's Avatar
Actually I tried this, but the key was not there when I used a software to remove the entry. Ohk I'll try again on Office computer and post it here if the key is still there....
Old 24-06-2011, 12:16 PM   #18 (permalink)
I am not sure about the method but: You can try uninstall the software then run ccleaner to remove all the related entries then reinstall. It might restore the registry keys and then you can try the above mentioned way via registry.
Abhinav
abhinav_sinha is offline   Reply With Quote
- by gforz
- by Anorion
- by tkin
- by Niilesh
