Hello guys,
I am facing a problem....
While I was uninstalling Kaspersky Internet Security 2011, electricity went off....
so as a result system is giving following problems....
1) since the KIS was not uninstalled completely some of the files r missing and hence i cant uninstall it now... i tried deleting some registry entries but in vain...
I also cannot install KIS2012 since it thinks that KIS2011 is still there and when it tries it unistall it, it cant find the necessary file..
I haven't deleted the files from the c drive to avoid further causing any problems ...
2)my windows gadget has also went kaput... they dont load now... probably happened because KIS2011 was trying to uninstall its gadget but electricity abruptly stopped it from doing so....
3)Windows Media Player also stopped functioning, i dont know how this relates with KIS2011 but it happened immediately after the above event....
Problem no. 2 and 3 are not so important,if they can be solved it will be just a bonus since i can live with them... but i dont want to have a pc without security... so kindly guide
