Hey all I bought my system 3 years ago it has a P4 3 GHz processor, 2 gb ram 1tb hdd. A few months ago i started experiencing a problem that any software that was bigger than 50mb in size won't install. It showed some or the other file of the setup is corrupted(every time it showed a different file was corrupted for the same setup) I thought it would be a virus problem so I formatted my system with windows xp sp2. but the problem remained.I thought i should go for linux instead of windows.I tired doing that but I could also not install linux on my system it showed some error in Cd/DVD or the hdd while installing. So i bought a new hdd but still the problem exists.The problem also exists for Vista. I am not able to install that too.So I also replaced my DVD drive hoping it had the fault but the same problem exists. I even tired formatting my system by USB but no linux (Ubuntu,Mint or Ferdora) would install and all would give the same error. I have downloaded different copies of software & OS but nothing works.
The software DVD's would work on my frnds system but don't on mine. I am only able to install small software like Chrome,Winrar,DivX etc. Other software like Microsoft Office 2007,Adobe Photoshop CS4,CS3,Dreamweaver CS4,CS3,Need for Speed Most wanted,VMware,CounterStrike etc every time show some or the other file is corrupted. The same copies work on my frnds computers but won't on mine
What is the problem with my system. Is it a hardware problem or a software problem. What should I do
