Old 19-06-2011, 10:59 PM   #1 (permalink)
Democracy is a myth
rhitwick's Avatar
Question Playlist editing issue
Well, let me first give a background of the scenario.
I use KMPlayer for listening audio. I created this playlist having 200 songs. The source of the songs were in an external drive. Now due to certain changes in h/w the external drive letter has changed (from J: to M and as an obvious the songs are not playing.
Now give me a solution so that I can edit the playlist to redirect the songs to play from new address (the folder structure is same only the drive letter changed)
S/W used: KMPlayer
Playlist format: M3U format
Drive letter changed: from J: to M:
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now   Reply With Quote
Old 20-06-2011, 03:59 PM   #2 (permalink)
Default Re: Playlist editing issue
I dont think there is any other way then re-creating a play list and re-adding files.
You may also try to create shortcuts of the songs in the previous location. That might do the trick
Old 20-06-2011, 04:24 PM   #3 (permalink)
Hmm kinda same proble also occured with me but I am using iTunes.
I use a simple solution. I opened the playlist in MS word now use the find and replace function to chance "/J:/" to "/M:/" . It worked for me as itunes stores files in its library as file:///C:/ so it was quite simple as nothing like /C:/ would exits in the name of any of the Music files you have so it won't corrupt them just change the drive letter. But if you try to change J to M it will also change them in the names of the songs which will cause trouble hence do the way I wrote above
Asmeet is offline   Reply With Quote
Old 20-06-2011, 10:46 PM   #4 (permalink)
Democracy is a myth
rhitwick's Avatar
Unhappy Re: Playlist editing issue
I just did that yesterday. Though, I opened it in notepad, replace all "J:" to "M:".
Now, when I open the playlist I find there are two entries of each song. One that plays and one that won't!!!
I opened the playlist again but found no repeatation there. I tried deleting duplicate entries from the palylist and saving as new, that too did not work.
Old 20-06-2011, 11:09 PM   #5 (permalink)
Might be some hidden file.
Faun is offline   Reply With Quote
Old 20-06-2011, 11:29 PM   #6 (permalink)
Democracy is a myth
rhitwick's Avatar
Guys problem solved. And it was with me only. No issues with KMP. Sh1t, I was so dumb.
Actually I had selected an option in KMP so that it would open all similar files in a folder. Now my modified playlist and old corrupted playlist were at same place. Everytime I clicked on the new one KMP also loaded the old one too.
Thus a working entry and non-working entry in playlist. Sh1t (happens)
- by Anorion
- by tkin
- by Niilesh
