14-06-2011, 03:51 PM
Write Fail
Hi
I am continously getting a write error whenever i burn data. I am attaching the error. I am buring at 4x with cdburner xp and using Windows 7 ultimate. I am using HP DVD writer.
Error Pic:-
14-06-2011, 05:56 PM
I'm a Wannabe Hacker
Re: Write Fail
Have you tried other than CDBurner XP? Chech with other s/w s.
From the error picture, it seems that the disc might have got corrupted. Does this happen with HP writer usually? or it happened with CDBurner XP only?
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning. - Rich Cook
14-06-2011, 06:16 PM
Re: Write Fail
Disc was OK For sure tried two brand new disc!!!
It was burning earlier good and fine b4 using CD Burner XP only
14-06-2011, 06:28 PM
Re: Write Fail
Try some alternatives like IMGBurn, Daemon Tools Lite, Ultra ISO or Ahead Nero.
If the problem still persists, then there must be problem with disk lens. You will need to clean the disc lens using Disc lens cleaner.
14-06-2011, 08:23 PM
Your Ad here
Re: Write Fail
AFAIK Ashampoo Burning Studio FREE really stands out from the rest in terms of freeness. It also supports multisession disks (not in CDBurnerXP). Try it.
Also, refer this thread - http://www.cybertechhelp.com/forums/...d.php?t=214854 to see if it helps...
“The Web is like a dominatrix. Everywhere I turn, I see little buttons ordering me to Submit.”
ASUS P5KPL AM/PS | P4 @ 3.07GHz | Ubuntu 11.04 / Win Server 2k8 / XP SP3 | 1GB DDR2 | Samsung HD080HJ 80GB
15-06-2011, 08:34 AM
Mozilla Rep
Re: Write Fail
Go for CDBurnerXP, I've been using it since Nero went down the hill and the results are quite satisfactory. Try using other softwares as mentioned above and report back.
Originally Posted by nisargshah95
CDBurnerXP has a multisession option, but not mentioned in the term you expected.
18-06-2011, 12:54 AM
Your Ad here
Re: Write Fail
Ohk. I used it long ago too. Sorry
18-06-2011, 12:39 PM
Fullbring
Re: Write Fail
@mohityadavx:Burn it using Nero once
18-06-2011, 02:34 PM
Freak Beta 1
Re: Write Fail
18-06-2011, 09:24 PM
Re: Write Fail
You can try a change of your cable. Though it may seem incorrect seeing yours reads discs (I presume of course), something like this happened with me too and with a cable change it started working fine. Prior to this I thought my drive has gone. I advice using a rewritable disc so as not to lose more disc in experimenting.
Abhinav
18-06-2011, 09:48 PM
Stuck in Time...
Re: Write Fail
I bought HP DVD writer first time hoping that it would be a good investment than LG. And it has paid me once already, when it wasn't even affected after a CD got blast inside! (It was a cracked CD, and I was being a smart a$$).
OP should try simulating first, before trying to burn, and try other burners.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
18-06-2011, 09:58 PM
Re: Write Fail
I am out of town rite now ( since 16th actually) will try as suggested and report back the same.
BTW Thanks All !!
18-06-2011, 10:25 PM
Living to Play
Re: Write Fail
Hmm try Asampoo Burning Studio. Never gave me any problems with burning.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
