Old 11-06-2011, 06:54 PM   #1 (permalink)
Exclamation Hard Disk Partition Problem
I have 4 partitions on my hard disk (all are NTFS).There is a local disk (F) and it always shows 64.5 MB free out of 103 MB.No matter what i do,this doesn't clean up.I want to delete this partition and merge it with other partition.What should i do?
Vatsal is offline   Reply With Quote
Old 11-06-2011, 07:21 PM   #2 (permalink)
Living to Play
gameranand's Avatar
Default Re: Hard Disk Partition Problem
Have you created this partition yourself or windows created it ????
If Windows Created it then don't do anything to this or Windows will stop working.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 11-06-2011, 07:32 PM   #3 (permalink)
it is done by windows , but there is no file (system) on it,as total size is 103 MB.
Old 11-06-2011, 07:44 PM   #4 (permalink)
Living to Play
gameranand's Avatar
Well those are system files in it and they are hidden so you arn't able to see them.
To see them
Go Organise -> Folder and Search Options -> View Tab -> The Select Show Hidden Files and Folders, Uncheck Hide Protected Operating System Files
Then you can see those folders and files but there will be security restriction to open them or to see the contents of that folder. Well You can break that security to see all the files but don't do that.
And don't modify or delete that partition alright.
Old 11-06-2011, 07:56 PM   #5 (permalink)
Mmmph!!!
doomgiver's Avatar
DONT DO ANYTHING!!!!
its system reserved space for keeping boot data, if you modify anything, your computer WILL FAIL TO BOOT.
anyway, 100 mb is a very small amount, its not going to affect anything, and its not a virus
you have created two threads. please dont do this. one thread is enough
Mmmphh-mphhhh-mmphh mhh!!!
Steam : doomgiver
doomgiver is offline   Reply With Quote
Old 11-06-2011, 11:17 PM   #6 (permalink)
Stuck in Time...
Vyom's Avatar
@Vatsal: I confirm too. That 100 MB partition is an auto created partition by Windows Vista or 7, to be used for System related tasks.
AFAIK, that partition is not given a drive letter by default, and so is not visible under normal circumstances, unless you give it a drive letter yourself!
You should remove the drive letter from that partition, OR hide the partition altogether using utilities like, Tune Up.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is offline   Reply With Quote
