my pc is infected by a virus it displays a file named "winfile.exe" its owner name is "gy"
and my kaspersky antivirus is detecting as "comment.htt" now what is the method of removing it need help
Reason: [SOLVED]
scan using McAfee AVERT Stinger & delete whatever it finds. alternately download QuickHeal & install it. it'll surely detect the virus & installation will be aborted & an option of scanning first will pop up. scan your system. then update kaspersky & do a full system scan to remove the last part.
or instead install Avira Antivirus without Shields (system guard). update Avira. start PC in safe mode. scan.
How to remove BiFrost virus winfiles.exe, winnt.exe, ggg.exe
