Old 04-06-2011, 06:12 AM   #1 (permalink)
mohityadavx's Avatar
Default Resolution problem
Hi!
I am having following config:-
ASUS VW193D 19"
Core2Duo E7400 @ 2.8 Ghz
Nvidia 8400GS @ 512 mb
Now i had been using my monitor @ 1600 x 900 resoultion since a long time
but yesterday when i switched on my monitor its resolution was at @ 1152x864
now when i try to get it back 160x900 is shows out of range . Please help what shall i do??
XPS 15 | Infibeam Pi |LG P500 |GoGear SA52XX | Sony PS2 | Sony H55 | Sennheiser CX 180 , MX760
For Free Legal Documentation - Rent Agreement/RTI etc
KAGZAAT
www.bleedlaw.com For Law student & aspirant
mohityadavx is offline   Reply With Quote
Old 04-06-2011, 08:03 AM   #2 (permalink)
Default Re: Resolution problem
Recduce the refresh rate of the screen first then try to switch it
If you dont know how to, Go to this link-
How To Change the Screen Refresh Rate of Your Monitor in Windows XP
Old 04-06-2011, 08:42 AM   #3 (permalink)
^^ its already at is lowest i.e. 60Hz
KAGZAAT
Old 04-06-2011, 08:45 AM   #4 (permalink)
Then try reducing colour depth to 16 bit.......that should help..
else reinstall drivers..
Old 04-06-2011, 09:04 AM   #5 (permalink)
Dust in the Wind
Skud's Avatar
Generally this occurs because of a corrupt driver. Uninstall the current driver and install the latest drivers.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 04-06-2011, 07:25 PM   #6 (permalink)
Living to Play
gameranand's Avatar
Reinstall display drivers and also try this on safe mode and see what happens.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 09-06-2011, 09:51 AM   #7 (permalink)
It is again back to normal without doing anything @ all seriously tis pc is getting my nerve now
KAGZAAT
Old 09-06-2011, 10:23 AM   #8 (permalink)
Fullbring
Zangetsu's Avatar
@mohityadavx: if its working now then keep it under observation....& if problem occurs again then reinstall the display drivers
