Old 29-05-2011, 11:59 AM   #1 (permalink)
Pirate Slayer
Cool Comps's Avatar
Default LG Cyberlink Software giving problems.
Hi people.
I bought my lg dvd writer and with it got cyberlink burning software. I installed this but when i click on lg burning software icon, an error comes which says "Failed to create empty document"
THen the windows dialogue box come and says "power2go.exe has stopped working"
Any solutions ?
What is causing the problem?
PS: I am using Win 7 Ultimate 64 bit
Also, is it the softwares fault, the hardwares fault, or the operating systems fault?
CPU : i5 2500 | Motherboard: Intel DH67BL | RAM: 4 gb corsair vengeance | HDD: 1 tb seagate |
GPU :Sapphire HD 6870 | PSU :Corsair TX650 v2 | Cabinet : CM Elite 430
Cool Comps is offline   Reply With Quote
Old 29-05-2011, 12:30 PM   #2 (permalink)
Default Re: LG Cyberlink Software giving problems.
Originally Posted by Cool Comps View Post
Hi people.
Any solutions ?
software problem
try install Ashampoo-Burning-Studio-6 and burn DVD/CD [Free full version ]
https://www.ashampoo.com/en/usd/pin/...rning-Studio-6
AMD Phenom II X6 1055T ,Benq G2220HD 22 ,GIGABYTE GA-880GM-UD2H ,COOLER MASTER Elite 310 ,CORSAIR 2GB 240-Pin DDR3 X3[6GB] , FSP Saga II 500 W HD 5750 . Hyper 212+ OS :Win 7 64 bit
Rajesh345 is offline   Reply With Quote
Old 29-05-2011, 12:30 PM   #3 (permalink)
arko1983's Avatar
install other writing software and check(ie nero or any free ones available).
I think it should work & check compatibility of ur lg software version ie supports win 7 64 bit etc.
core i7 920,gigabyte ex 58 extreme
corsair 1000hx,corsair 3x2gb dominator
msi gtx 580 twin frozr ii/oc,
coolermaster atcs 840,g500+razer exactmat +g510
24" dell led monitor, 1.5 tb seagate +2 tb green wd
arko1983 is offline   Reply With Quote
Old 29-05-2011, 01:21 PM   #4 (permalink)
Living to Play
gameranand's Avatar
Just use some other software for burning like Burnaware free, Burn 4 Free, Asampoo Burning Studio. I would recommend Asampoo.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 29-05-2011, 02:04 PM   #5 (permalink)
Pirate Slayer
Cool Comps's Avatar
thats ok.
But i need to know why its not working..
is it a hardware problem, software problem, or Operating sys problem
PS: On the disc its printed : Compatible with windows 7. Doesnt say 64 bit/32 bit
And btw ImgBurn can copy discs?
Old 29-05-2011, 02:12 PM   #6 (permalink)
the m0nk who sold his PC!
MatchBoxx's Avatar
ImgBurn is excellent too
Intel i5-2400 || ASUS P8H77-M || G.Skill RipjawsX 8GB (4GBx2) || MSI HD6850 Cyclone PE || Corsair GS600 || Cooler Master Elite 431(Side Panel) || Dell ST2220L || Edifier C2 || APC 1.1 kVA || Seagate GoFlex 1TB
(WBUT semester routine announced. I'm OFF for the time being.)
MatchBoxx is online now   Reply With Quote
Old 30-05-2011, 03:13 AM   #7 (permalink)
shayem's Avatar
thats ok.
If you can send me that software you have..I'll test it and let you know.
shayem is offline   Reply With Quote
Old 30-05-2011, 04:53 AM   #8 (permalink)
Mozilla Rep
sygeek's Avatar
I personally like CDBurnerXP over Imgburn or other free burning softwares out there. However I've come to know that Ashampoo Burning Studio is good too.
sygeek is online now   Reply With Quote
Old 30-05-2011, 06:43 AM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
thats ok.
seems like a compatibility issue between the OS and the software.
Try IMgBurn - if it writes a disc without any issue then your drive is fine.
ToPsPeEeD = FaSt BuT StEaDy
topgear is online now   Reply With Quote
Old 30-05-2011, 05:59 PM   #10 (permalink)
Pirate Slayer
Cool Comps's Avatar
ok^^
btw i have chosen to change to win 7 32 bit. Hopefully the software will work on that
after a year or so ( when my board exams r done i will change back to 64 bit as i will have time for research)
My board exams r also the reason i have to come less to the forum. Gonna miss you awesome people!!
how can i send it bro?
