Originally Posted by Sarath
I think I got misdirected into downloading a FAH file and installing it. The process shows fahcore_a4.exe utilising all my cores at 100% and the GPU too.
I tried ending the process but it kept coming back.
How to uninstall this as it is not a program which shows in Program Files?
u can disable it from
Sstart >Run>msconfig >Startup > disable it from here
if u cant find it there then it is started as service (for xp system)
Start>RUn>services.msc > disable it from there
Note : By running F@h client u r contributing ur Pc's CPU and GPU for Research in Medical Field
You can help scientists studying these diseases by simply running a piece of software.
Folding@home is a distributed computing project -- people from throughout the world download and run software to band together to make one of the largest supercomputers in the world. Every computer takes the project closer to our goals. Folding@home uses novel computational methods coupled to distributed computing, to simulate problems millions of times more challenging than previously achieved.
http://folding.stanford.edu/
