Old 28-05-2011, 04:48 PM   #1 (permalink)
Default problem with swf files
i downloaded a tutorial and later found out that they are some .swf files.Some files play with audio and some do not play with audio in web browser..there is a index file but its not linking files for 2 folders 1)audio 2)visual.. Is there any flash player which can help me instead of playing these files in web browser?? Iam a newbie, so weak in this
niteshatdigit is offline   Reply With Quote
Old 28-05-2011, 07:41 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: problem with swf files
VLC should be able to run those files fine I guess. If not try rich Internet applications | Adobe Flash Player
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline   Reply With Quote
Old 29-05-2011, 07:47 PM   #3 (permalink)
Two ways:
1. Either download a .swf opener.
2. Make a standalone .exe file for which you can download Adobe flash professional trail then open the .swf file. go to file>>create projector>>save the file (Remember if .swf is in few kb it will be about few mb in .exe)
Abhinav
abhinav_sinha is offline   Reply With Quote
Old 29-05-2011, 09:50 PM   #4 (permalink)
Mozilla Rep
sygeek's Avatar
I guess you can merge both the files with a software like Adobe Flash Player Professional or Macromedia Flash Player (Older than Adobe's Flash player but better, not bloated like Adobe Flash Professional).
OR there are many swf mergers software you can search for in Google.
sygeek is online now   Reply With Quote
Old 30-05-2011, 04:00 PM   #5 (permalink)
Thanks for the info
Old 30-05-2011, 04:05 PM   #6 (permalink)
You can also convert them to mp4,flv using Total Video Converter or anything similar
