Hi,
I have win xp on D: I had run Zonealarm Antivirus (which comes as a part of zonealrm security suite) it found virus in the system volume information folder of both my C: and D: the virus was identified as Backdoor.Berbew (something like that) and was removed.
I searched the net and found some removal techniques. I checked the registry but could not find the entry which this virus makes. One of the symptoms was that the internet settings are put to custom level from default level. This happened recently. that same virus is not found on my hard disk now.
There is a folder named _restore{D2E........ the name is very long.
I want to know whether this folder is created by the virus or not.
i could see the folder only through dos.
Also my pc has become very very slow.
thanks in advance.
