Old 25-05-2011, 01:36 PM   #1 (permalink)
Angry overloaded fonts
my younger brother installed 10,000 fonts in my Pc,now im having problem with fonts specially when im using Photoshop my pc hang up for 3-4 mintues to load fonts.but i dont want delete windows default fonts,is there any way to extract default fonts from windows xp bootable cd,so that i can delete all 10,000 fonts and install windows default fonts or is there any way to load fonts faster in photoshop cs5
syner is offline   Reply With Quote
Old 25-05-2011, 03:03 PM   #2 (permalink)
Default Re: overloaded fonts
Try doing a system restore to a date before they were installed.
Back up any .exe's you may have installed after that
Old 25-05-2011, 03:51 PM   #3 (permalink)
remove fonts - Microsoft Answers
reply by SpiritX MS MVP
Hi,
Install or uninstall fonts
http://windowshelp.microsoft.com/Win...bde301033.mspx
How Do I Remove, Uninstall, and/or Disable Fonts?
http://tiplet.com/tip/how-do-i-remov...disable-fonts/
Font Frenzy - Remove easily - Free
http://sdsoftware.org/default.asp?id=5936
Font Explorer - Free
http://www.karenware.com/powertools/ptfonts.asp
Hope this helps.
Download link Download
got from google searching
AMD Phenom II X6 1055T ,Benq G2220HD 22 ,GIGABYTE GA-880GM-UD2H ,COOLER MASTER Elite 310 ,CORSAIR 2GB 240-Pin DDR3 X3[6GB] , FSP Saga II 500 W HD 5750 . Hyper 212+ OS :Win 7 64 bit
Rajesh345 is offline   Reply With Quote
Old 23-06-2011, 03:56 PM   #4 (permalink)
In Shameful Misery
Scientia Wiz's Avatar
Go to control panel and then click the font folder and then select all the fonts and delete them after deleting them restart your computer and you will get your default fonts back !
Scientia Wiz is offline   Reply With Quote
